compression tester
I got a compression guage to check the compression after rebuilding the top end. It is one that you have to hold in place it does not screw in to the head. I am just not sure of the proceedure. do I only take 1 plug out at a time? do I have to seal the carbs or exhaust? The whole bike is back together and dont really want to take apart again.
dont seal anything off. and I always do it one at a time just my preferance dunno if it matters to leave 1 plug in and check it or not but i do. and I've used the one you are talking about make sure you push down relativly hard while its being kicked or it won't be air tight.
dude, take a plug out, have someone hold it in place, hold the throttle wide open and kick it over and over really fast as if running like 15 times with the coil disconnected. then the same other side. those hold in place ct`s are garbage, but as long as its sealed very well, it may work.
i asked a similiar question today in the sticky thread "leakdown test" page 3.-----
After i perorm leakdown tests on by shee and the 250 i want to do compression test i have the guage with the correct sparg plug thread hose, does anyone know the prpoer way to do the test/or know a link? I test the shee cylinders seperate yes? If the cyclinders areant seperate via the crank how will the comp test read per cylinder? and for the single cylinder how many times to turn it over?
QUOTE (black sunshine @ May 27 2009, 02:02 PM)
6psi for 6 min is the recommended test.----leakdown test
For compression, take out both plugs, turn ignition and gas off, hold the throttle wide open and kick until the gauge quits climbing.
Quote (kawa110 @ May 27 2009)
sounds good.
6psi for single cylinder?(all engines?, i have klx110 and eventually ill test it)
Just kick until stops climbing 3 kicks or 12 kicks it wont matter?
I take one plug out, screw in compression tester. Kick until compression needle stops moving. I do not hold throttle open. If you buy a compression tester look for the adapter that has about the same length on the threads as the spark plug you are using.
Your suppose to hold it WOT when you kick the crap out of it for testing compression. Kick till it wont climb anymore. Then do the test 1 or two more times just incase it didnt seal good. Might give you a false reading that is too low.
Simply not correct.. Except for the length of threads on the adapter part.. :thumbsup:
Cajun here has it..
Its important to have a correct tester. The one you describe I wouldn't trust anymore than throwing darts at a board with PSI readings on it. You could try but so little makes such a huge difference.
Otherwise, take out BOTH plugs, your gonna be kickin like a mofo, this helps to let her turn over a bit easier.. Hold at WOT, this actually lets the air in to get the reading. Has to fight through that carb your gonna be looking at a leg that may feel as though its gonna fall off to get the # up. Like Cajun said, kick untill it stops. If I remember correct I think I usually have to kick 35-40+ to get there.
RIPPEN
Some good and bad info in here.
-Get motor to operating temp
-Remove plugs
-Ground plug caps to motor as to not short your electrical system
-Insert comp tester
-hold throttle wide open and kick hard until reading does not climb anymore
-repeat 3-4 times to verify correct reading
-swap sides, repeat.
Cold rings in a cold cylinder will give a different reading that warm rings in a warm cylinder. You want PSI at operating temp.
Get a threaded comp tester with the threads the same depth as the spark plug.
Good rule of thumb is to take a reading with a freshly broken-in top end. When that initial numbers drops 15% its time for another fresh top end.
-Remove plugs
-Insert comp tester
Didnt know had to ground the plug boots. Could i just use a wire for each plug boot that has a alligator clip in each side and stuff one side in boot to clamp on lead then the other clip to the frame. (one wire for each boot)?
correct me if I'm wrong but if the ignition is off I don't think it is an issue.
I recently lost my key(more mad about losing the picture of my dog that just passed keychain that was with the key) and mad cuz i had to wire the bike until i get a new ignition and 2 keys.(need that spare)
The red swith will also kill spark wont it?(my keyed igniton is wired)
