sandman1 Posted May 24, 2009 Report Share Posted May 24, 2009 I just bought a Shee in pieces and am going to rebuild it. I bought a used crank off ebay but noticed that the space between the rods and the counter weights are different on the two sides. Can I close the gap with a press or how can I fix the problem? Also does any one know where I can dowload a free service manual? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
sandman1 Posted May 24, 2009 Author Report Share Posted May 24, 2009 I found the service manual. Quote Link to comment Share on other sites More sharing options...
sandman1 Posted May 25, 2009 Author Report Share Posted May 25, 2009 surely somebody here knows about Banshee cranks Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 25, 2009 Report Share Posted May 25, 2009 surely somebody here knows about Banshee cranks If your crank is separating you don't wan to run it. Send it back and get a refund. It will cost you more to have it rebuilt then what you can buy a used one for. Pressing it back together isn't wise either. It could very well be out of phase. When you get another one get it welded so that doesn't happen! Good luck. SP Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted May 25, 2009 Report Share Posted May 25, 2009 If the bearings feel good then. I would call jeff at FAST and explain to him what you have. He would should be able to press it back together and true it up and tig weld it so it doesn't seperate or twist out of phase. Yea you could press it back together and weld it your self but if it isn't true or in phase you could get a nasty vibration. Jeff is a good guy to do business with. I will let you ride my banshee so you can see what you think of his port work. His screen name on here is FASTOYS www.farmandsandtoys.com Josh Quote Link to comment Share on other sites More sharing options...
sandman1 Posted June 3, 2009 Author Report Share Posted June 3, 2009 Thanks man I called him now it's on it's way there. Quote Link to comment Share on other sites More sharing options...
