bansheesickness Posted May 23, 2009 Report Share Posted May 23, 2009 does anyone have a diagram or instructions on how to install a pancake bearing? i have an idea of how it works but just want to make shure. Quote Link to comment Share on other sites More sharing options...
bansheesickness Posted May 25, 2009 Author Report Share Posted May 25, 2009 any one? Quote Link to comment Share on other sites More sharing options...
Natemills8 Posted May 25, 2009 Report Share Posted May 25, 2009 you put the bearing in place of the thing where you adjust the clutch under the cover you have to but the adjustment screw in the bearing are you putting a lock up on what kind are you using because if you are putting one on from DD or GRR you have to do it a certin way Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 25, 2009 Report Share Posted May 25, 2009 The pressure plate goes between the two washers. Adjust clutch and done. http://rc.superdave2u.com/MyBanshee/pancak...g%205-12-09.JPG Quote Link to comment Share on other sites More sharing options...
bansheesickness Posted May 26, 2009 Author Report Share Posted May 26, 2009 i got one form hjr. its for a stock clutch. so you still use the stock wasther and 12mm nut on the outside? Quote Link to comment Share on other sites More sharing options...
Rodneya Posted May 26, 2009 Report Share Posted May 26, 2009 Yes. You could probably leave the stock washer off Quote Link to comment Share on other sites More sharing options...
