IF YOU COULD ONLY DO 1
i used 5mm as an example
and you do NOT have to trench for a 5mm
i wanted to know which will give the BIGGEST gain..........STROKING OR BORING
Where do you want the GAIN? Who does a 5mm stroke anyway? Pipes, carbs, reeds, track, budget, goal??
ive seen people being told a million times boring does nothing on a stock cylinder but waste the life of your cylinder. stroke it with a nice port job and you'll be happy. just my .02
Knowing your goal is a good thing...........
In the two stroke world there are two conceptual ways to make power: Piston speed and/or combustion chamber volume. I am a piston speed type of guy, so I would be looking at a small bore with alot of stroke, or a big bore with not much stroke. The OEM Banshee config. does not support a bore large enough without extensive modification to make sense, so if you were to do just one thing, adding stroke is how to get the job done.
Iwas on a website that offers alot of different engine combos and all with the stock cylinders are stock bore with lots of port work but different crank sizes
they have a
4mil stock bore
5mil stock bore
7mil stock bore
even a 10mil stock bore on stock cylinders
and FYI hotrod makes a 5mil that will drop right in.
Ok. Calm the hell down. The only person I seen on here with a 5mil, had to trench. I'm guessing it just depends on the pin size?????
I don't think any of the crank manufacturers offer a larger pin size......... If the guy had to trench for a 5mil, he probably had a mismatched set of cases or they were tweaked. You should only have to trench for a 5mil if your cases are junk. :biggrin:
this is with ALL things being = except one has been bored 5mm and one stroked 5mm.........which would show the most gain on a dyno ?????
Well, is that on stock ports, mild ports, or highly modded ports? That will make all the difference of how each performs.
Brandon
