NickisGod Posted May 18, 2009 Report Share Posted May 18, 2009 how do u remover the pressure plate? i seized my clutch and can seem to remove the bitch, i took it off once before but all i remember doing is just unscrew 6 screws and pull it off with my hand. but now i cant seem to get it off, i dont wanna use a jaw puller but i need to remover this, but i needs to be removed Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted May 18, 2009 Report Share Posted May 18, 2009 Take the 6 bolts out, and it should fall off. Quote Link to comment Share on other sites More sharing options...
NickisGod Posted May 18, 2009 Author Report Share Posted May 18, 2009 Take the 6 bolts out, and it should fall off. hum im pretty sure i tryed that....... Quote Link to comment Share on other sites More sharing options...
ned Posted May 18, 2009 Report Share Posted May 18, 2009 is your clutch cable still connected? Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted May 18, 2009 Report Share Posted May 18, 2009 (edited) is your clutch cable still connected? That makes no matter, once you remove the 6 bolts it should fall right off. You welded the ball didnt you? Is your clutch adjuster hanging up on the outside and conneted to the ball and pushrod? Just a thought, but yeah, it should just fall right off. Edited May 18, 2009 by boneyardbanshee. Quote Link to comment Share on other sites More sharing options...
blowit Posted May 18, 2009 Report Share Posted May 18, 2009 Adjuster is likely welded up. Remove the center adjuster bolt and the pressure plate should come of after that. That will leave the adjuster in the clutch hub. Brandon Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 18, 2009 Report Share Posted May 18, 2009 Adjuster is likely welded up. Remove the center adjuster bolt and the pressure plate should come of after that. That will leave the adjuster in the clutch hub. Brandon +1. If things are welded together, the adjuster is keeping the plate on. Hopefully after that it off you can pull the adjuster, ball and pushrod out. If not, you'll be splitting the cases. :ermm: . It might help to tip the bike on it's side to let gravity help. But that's after the pressure plate is off. Quote Link to comment Share on other sites More sharing options...
trex565 Posted May 18, 2009 Report Share Posted May 18, 2009 when you get apart get ajuster with bearing on it keeps it from welding togather you will have to make hole in pressure plate round so it will fit good luck Quote Link to comment Share on other sites More sharing options...
