should i get a lockout?
I had a good port job on stock juggs and 6 hd springs worked fine. I just went with a 4mil set up and then i needed a lockup.
But if i had to do it over again, i would get a lockup. Reason is for easier clutch pull. You can run 3hd/3 regular with a lockup. Then you have easy clutch pull and a clutch that doesnt slip.
I run a vito's undercover slingshot style. Works great! Only $220.
I run a Direct Drive lockout, on an extreme dune ported stock crank. I love mine. Do not run any HD springs, you dont need them. When the engine in at the higher rpm it pulls the clutch plates in tighter. If you can afford it do it. Saves clutch fibers IMO.
