oneslowshee Posted May 10, 2009 Report Share Posted May 10, 2009 So i have power jets on my 40mm hv lectrons, how do you know if they are working? it does not seem like the fuel is going up to the jets from the bottom of the bowl? in the line it looks like its only going 1/2 way up the line? but i am not looking at it when i am running it? any ideas? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted May 10, 2009 Report Share Posted May 10, 2009 your not generating enough vacum at idle. when you wic the throttle you should see the fuel level jump up.. but it wont fully reach the PJ. Quote Link to comment Share on other sites More sharing options...
oneslowshee Posted May 10, 2009 Author Report Share Posted May 10, 2009 your not generating enough vacum at idle. when you wic the throttle you should see the fuel level jump up.. but it wont fully reach the PJ. so what do i do correct this problem? Quote Link to comment Share on other sites More sharing options...
oneslowshee Posted May 10, 2009 Author Report Share Posted May 10, 2009 so what do i do correct this problem? how exactly do these things work? i am not even sure how to tune them... thanks in advance Quote Link to comment Share on other sites More sharing options...
shanYE west Posted May 10, 2009 Report Share Posted May 10, 2009 when you wic the throttle you should see the fuel level jump up.. but it wont fully reach the PJ. so what do i do correct this problem? There is no problem as long as what I stated is happening.. thats the way they are. the fuel wont reach the PJ's by sitting there. if you wic the throttle and the fuel level jumps in the line, then the PJ should be functioning correctly. Quote Link to comment Share on other sites More sharing options...
oneslowshee Posted May 12, 2009 Author Report Share Posted May 12, 2009 There is no problem as long as what I stated is happening.. thats the way they are. the fuel wont reach the PJ's by sitting there. if you wic the throttle and the fuel level jumps in the line, then the PJ should be functioning correctly. so how exactly do i tune them? never understood if i should turn them all the way up or what? Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 12, 2009 Report Share Posted May 12, 2009 You will want to start w/them wide open, And go down from there. When I am trying to jet my bike I make 3 or so passes, check the plugs, close down the pj's half turn at a time(if it's rich) and repeat. Do you know how to read alky plugs? Quote Link to comment Share on other sites More sharing options...
joee20002 Posted May 12, 2009 Report Share Posted May 12, 2009 You will want to start w/them wide open, And go down from there. When I am trying to jet my bike I make 3 or so passes, check the plugs, close down the pj's half turn at a time(if it's rich) and repeat. Do you know how to read alky plugs? how do you read alky plugs? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted May 12, 2009 Report Share Posted May 12, 2009 how do you read alky plugs? Hard to explain.. but you read the heat of the plug rather then the color. Someone could probably explain it better then I can. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted May 12, 2009 Report Share Posted May 12, 2009 (edited) how do you read alky plugs? Enjoy.... http://www.dragstuff.com/techarticles/read...park-plugs.html Edited May 12, 2009 by Bansh-eman Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 12, 2009 Report Share Posted May 12, 2009 how do you read alky plugs? That is a good article, but is nice to have pics. Are you going to be at Silver Lake this weekend Joe? I can give you a hand if ya like. I will be at WMSD on Friday and the dunes Saturday and Sunday(Woooohoooo LOL!). Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 12, 2009 Report Share Posted May 12, 2009 how do you read alky plugs? Since you are a PS member, here is a link w/some great reading and a few pics if you haven't seen it already. http://www.planetsand.com/forums/ubbthread...topics/654196/7 Quote Link to comment Share on other sites More sharing options...
J-Madd Posted May 12, 2009 Report Share Posted May 12, 2009 Unless you are trying to get every last bit of hp out of the motor, you can always start with them open, then start closing them by 1/2 a turn or so until the engine runs clean. Make sure the cylinders aren't getting too hot. This is a very safe way to tune, but of course reading the plugs will get you closer to max potential hp. Quote Link to comment Share on other sites More sharing options...
joee20002 Posted May 13, 2009 Report Share Posted May 13, 2009 That is a good article, but is nice to have pics. Are you going to be at Silver Lake this weekend Joe? I can give you a hand if ya like. I will be at WMSD on Friday and the dunes Saturday and Sunday(Woooohoooo LOL!). thanks bro .. ya i will be there saturday..... Quote Link to comment Share on other sites More sharing options...
