dunerunner37 Posted May 8, 2009 Report Share Posted May 8, 2009 I'm overhauling my top end I ordered my pistons and gaskets. They came in today, instead of geting two base gaskets I got a one piece metal re enforced gasket that looks like it's made for cub cylinders, the area between the jugs is real narrow, has anyone ran one of these Quote Link to comment Share on other sites More sharing options...
flyhighprerunner Posted May 8, 2009 Report Share Posted May 8, 2009 I think you should be alright man whats the thinkness of the base gasket? Quote Link to comment Share on other sites More sharing options...
bansheesickness Posted May 8, 2009 Report Share Posted May 8, 2009 you could try yamabond if your worried about it. its what i usualy run. Quote Link to comment Share on other sites More sharing options...
dunerunner37 Posted May 8, 2009 Author Report Share Posted May 8, 2009 you could try yamabond if your worried about it. its what i usualy run.the gasket is .028 thick, i called the place backk that sold it to me and they said to run it, they said its what they use on there builds and when they port the jugs Quote Link to comment Share on other sites More sharing options...
spurdy Posted May 8, 2009 Report Share Posted May 8, 2009 the gasket is .028 thick, i called the place backk that sold it to me and they said to run it, they said its what they use on there builds and when they port the jugs I am running the same gasket. A little more difficult to match to the cases and your jugs if they are matched to each other but not bad. I just used a drimmel. SP Quote Link to comment Share on other sites More sharing options...
Prototype69 Posted June 4 Report Share Posted June 4 I have same problem had to get new gaskets cause some how water had bubbled up under my base gasket guessing water jacket plugs leaked but do ya really have to trim it Quote Link to comment Share on other sites More sharing options...
