No Preassure on the Clutch lever?
Can you disengage your clutch? If not you might have welded your ball to the pushrod in your clutch assembly.
Yeah I can disengage it. But have to pull it back out. Its like you taking your line off but putting a little tension not much at all on it. I don't think it welded it because I can putt the push rod out? Any ideas.
im not 100% sure if discribing is what im thinking u are but check the big nut in the clutch. like in the middle of the plates and all that holds the basket.if the tab on that washer broke off the nut will losen and you will have no clutch at all. like u would have to shift with no clutch. haha that just happend to me.
did it happen while riding it??
