Wont go in gear
was out on the trails yesterday and the bike stopped moving. engine runs but i think i smoked the clutch. the clutch will engage the pully by the shifter but i look into the case and the basket doesn't move. anyone got any ideas. i think i might have fused the plates together...oops. the bike will roll freely in any gear, its almost like its stuck in neutral
Edited by Alysiak00
ok let me get this straight... you put it in any gear and it does roll or it does not? From what I gathered it sounds like it just sits there when in any gear... is that correct?
When you pull the clutch lever is there any pressure on it?
You SMOKED the clutch. I had the same thing happen to me when I was ripping across the dunes. When you take it down check your basket for grooves and if you dont have a pancake bearing in there spend the $50 for the insurance.
awsome dude thanks man for the help. yea we were out at the rumble on the ridge over the weekend. i came up a hill and the bike didn't move with the throttle pegged. the bike runs but no matter what gear the bike is in (1st 2nd 3rd whatever), the bike rolls freely. if i pull the clutch in there is pressure and it moves the lever to the left of the bike by the shift lever. i opened up the case while pulling the clutch and the basket doesn't move. the clutch has to be shot
