NN2 Posted May 5, 2009 Author Report Share Posted May 5, 2009 I would like to ask you a question if I may How did you center the twin motor in a single cylinder frame?? I have a complete yfz roller chasis you have me interseted It's not exactly centered but close. Just aligned the front sprocket with rear and that's where it sits. You can't offset it to one side or the other because of the rear sprocket unless you fab some other stuff up to make it work. I used a jack to hold the motor in place along with some wood shims to get it where I wanted it. Then I made motor mounts to fit. Quote Link to comment Share on other sites More sharing options...
Money Pit Posted May 6, 2009 Report Share Posted May 6, 2009 Do you think this will create any weight distributions in the air maybe pull it to one side or the other or do you not think it's a big deal, or just wait and see until you ride it Quote Link to comment Share on other sites More sharing options...
NN2 Posted May 6, 2009 Author Report Share Posted May 6, 2009 Do you think this will create any weight distributions in the air maybe pull it to one side or the other or do you not think it's a big deal, or just wait and see until you ride it I've thought about that and don't think it will matter much. If it doesn't cause me to cartwheel over a dune then I should be ok. I'm more concerned about the +4 swingarm. Maybe it should be an attempt posted on youtube :biggrin: . Quote Link to comment Share on other sites More sharing options...
Damon33 Posted May 6, 2009 Report Share Posted May 6, 2009 Looks good man Quote Link to comment Share on other sites More sharing options...
banshee_terror_ Posted May 6, 2009 Report Share Posted May 6, 2009 umm for the rad if it over heats you could get bigger radiators. or thicker ones. that should help allot and i was wondering the same thing will it pull one way in the air. it looks like there is only one way to find out Quote Link to comment Share on other sites More sharing options...
sangheraent Posted May 7, 2009 Report Share Posted May 7, 2009 I was thinking about doing this to a bike I had before and I read somewhere that DG pipes fit without chopping the pipes. I dont know how good of a pipe dg is but if it fits its cheap. Quote Link to comment Share on other sites More sharing options...
