krss144 Posted April 27, 2009 Report Share Posted April 27, 2009 So Sat. came around and went to try and start the shee and wouldnt start. So after taken everything apart and checking all electrical still nothing. So the only left was to see inside the engine. Took the head off and the top of the pistons looked ok. I noticed a lot of slop/play in the piston, a lot of movement. So after studing for sometime I noticed a little of the coolant got on top of the piston, so I was moving the piston up and down and could notice air bubbles coming up inbetween the piston and the walls. Cant have compression with air coming through. So time to take it down to father-in-laws and have him bored out. The side walls had no more cross hatches that you could see.Nothing looked like it came off nor big dents or scratches anywhere. Once I find out if it was stock or not I can then order a new topend kit. I found Vitos Super Stock Piston kit and wanted to know the good and bad about these or anything else out there that anyone can suggest looking into? Vitos claims mid to top rpm power increase 8+ hp. I know I will have to rejet but does anyone know if I will have to change my fuel/oil ratio? I am runnning Klotz 32:1. Thanks. Quote Link to comment Share on other sites More sharing options...
SANZI Posted April 27, 2009 Report Share Posted April 27, 2009 Vito's are a bad idea. I ride with a group of 11 Banshees and we all use regular Wiseco pistons. Vito's are Wiseco but the skirt are shorter. I've seen the skirts break over and over. Best way is bore it, wiseco pistons and a vito's base gasket(one full gasket, not two seperate ones). Klotz oils burn dirty. All of us run Castor 927 @ 32:1 with no problems. Quote Link to comment Share on other sites More sharing options...
krss144 Posted April 27, 2009 Author Report Share Posted April 27, 2009 I will keep that in mind, thanks for the info. Anyone else? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 27, 2009 Report Share Posted April 27, 2009 Klotz oils burn dirty. All of us run Castor 927 @ 32:1 with no problems. That is the most retarded statement I have herd. Castor oil burns dirty. The same type of oil that is in your Castor 927. Did you ever stop to think that maybe Klotz has different types of oil and not just 1. Quote Link to comment Share on other sites More sharing options...
UnrealBanshee Posted April 29, 2009 Report Share Posted April 29, 2009 (edited) Vito's are a bad idea. I ride with a group of 11 Banshees and we all use regular Wiseco pistons. Vito's are Wiseco but the skirt are shorter. I've seen the skirts break over and over. Best way is bore it, wiseco pistons and a vito's base gasket(one full gasket, not two seperate ones). Klotz oils burn dirty. All of us run Castor 927 @ 32:1 with no problems. Thats the same setup i use and i have a vitos cool head with the weisco pistons...i run the exact oil and mix ratio Edited April 29, 2009 by UnrealBanshee Quote Link to comment Share on other sites More sharing options...
krss144 Posted April 29, 2009 Author Report Share Posted April 29, 2009 Thats the same setup i use and i have a vitos cool head with the weisco pistons...i run the exact oil and mix ratio So no problems then? Was it worth the money? Notice any difference comparied to OEM parts? Quote Link to comment Share on other sites More sharing options...
moneybags Posted May 1, 2009 Report Share Posted May 1, 2009 WSM makes some good pistions. Little spendy thow. Quote Link to comment Share on other sites More sharing options...
Darthwall Posted May 1, 2009 Report Share Posted May 1, 2009 try the WSM pistons they are coated and really light weight very comparable to wiesco and if you look around you can get them for alil bit less Quote Link to comment Share on other sites More sharing options...
krss144 Posted May 8, 2009 Author Report Share Posted May 8, 2009 Last week I found out that everything was stock and my father-in-law suggested only going .10 over, but he also wanted me to use OEM parts. I just told him not to worry about the parts ans I'll just let him know how much to bore. I called Vitos and tried ordering the Super Stock Piston kit for .20 over, they where out of stock and could take a month'n half to get some more in. But they had the Super Stock kit with the .40 over bore on sale, so thats what I got plus a jet kit all for the price I was going to spend on just the .20 kit. I ordered the kit last Friday and was on my door step on Monday, very good people to work with. I finally had some time yesterday to start working on putting the shee back together, my buddy and I started at 4:00 and I was doing test rides by 6:30 and thats even including a bath for her. All I can say is WOW I was impressed. So worth the money, sounds a little meaner also. Now when the power band kicks in you know it. Changed the needle, jumped up one size in the main jet from a 320 to 330's, might have to turn the air srew just a little more. Bottom end is just a little rich but I would rather have it rich during break in then slowly lean it up. Quote Link to comment Share on other sites More sharing options...
BlasterKX Posted May 8, 2009 Report Share Posted May 8, 2009 so instead of going just 10 over and saving some life on your cylinders you went to 40 over? i would have just called weisco and asked for the 10 over kit. Quote Link to comment Share on other sites More sharing options...
krss144 Posted May 8, 2009 Author Report Share Posted May 8, 2009 Saving life,ya... but you can resleave it after you go .100 over. Not really to worried. I dont race it, I dont ride it everyday. I mainly ride it around the neighborhood and take it out on the trails like once or twice/month. I hope I get 3years out of it, but thats why I'll just keep an eye on it and come this fall open it back up and take a look inside. Parts are cheap for this toy...way cheaper then the sleds. I really didnt want to go to the .40 over at first but its only a mm difference. And the walls are a little thinner so I'll just have to remember it could overheat faster now. Oh and Vitos pistons are from Wiesco, and the piston kit from Wiesco was more $. Quote Link to comment Share on other sites More sharing options...
TwistedSheeRida Posted May 8, 2009 Report Share Posted May 8, 2009 yeah i definitly would have just bored it over what i had to if i were you but whatever floats your boat. i believe wiesco makes up to a .090 over bore kit so you just really shortend the life on your cylinder. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted May 10, 2009 Report Share Posted May 10, 2009 so instead of going just 10 over and saving some life on your cylinders you went to 40 over? Yuo, now i've think i've seen it all. :shoothead: and +1 on vitos. Their service and customer tech help lines are very nice! Quote Link to comment Share on other sites More sharing options...
dragbanshee98 Posted May 10, 2009 Report Share Posted May 10, 2009 Yuo, now i've think i've seen it all. :shoothead: and +1 on vitos. Their service and customer tech help lines are very nice! x2 on that... i run vitos pistons along with alot of the bikes that my motor builder does... there are prolly 10 bikes that i run with that have his motor setup and nooone has a prob with there stuff Quote Link to comment Share on other sites More sharing options...
messer007 Posted May 17, 2009 Report Share Posted May 17, 2009 I like the Vitos piston setup they work real good if you have you exhaust ported right Quote Link to comment Share on other sites More sharing options...
