Coolant leak
Loc
Here is the problem. I go out and start my Banshee every day and let it run for about 10 minutes. Today it is warmer (85) and It started to leak coolant out the front overflow hose. I noticed that my radiator is full and my overflow tank is full. Is the leaking because there is to much fluid or do I have a bigger problem. Thanks
That is kind of a long time to be sitting idle. Especially the warmer it gets. There are a few possibilities as well. Your pilot could be partially clogged or just plain lean. There could also be a problem w/your impeller. Neither of these things make sense if you have been doing this in colder weather w/o any problems. Something easy you could try is closing down the airscrews a bit. Will tell you if it is a lean pilot ckt if that fixes the problem.
