toolman Posted April 21, 2009 Report Share Posted April 21, 2009 I have a trans problem and need new top end gasket went to order them and they need to know the bore size. I can not remember the size do i really need to tell them the bore size. thanks Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted April 21, 2009 Report Share Posted April 21, 2009 I have a trans problem and need new top end gasket went to order them and they need to know the bore size. I can not remember the size do i really need to tell them the bore size. thanks Ive never needed a bore size. If you went to a powersports shop, most likely they are a fucktard. Unless they want to know it you have a big bore/cub cyl? Quote Link to comment Share on other sites More sharing options...
toolman Posted April 21, 2009 Author Report Share Posted April 21, 2009 Nothing special. i just can't remember the bore size it has been a while. I have not taken it apart and wanted the gaskets so i could put it right back togather. They told me cometic you have to have the bore size and they also sold versa and they did not require a bore size. I wanted the cometic because i have had good luck with them and cheaper than OEM. Quote Link to comment Share on other sites More sharing options...
DopeyTripod Posted April 21, 2009 Report Share Posted April 21, 2009 parts guy sounds like a lazy fuck that dont want to help. Quote Link to comment Share on other sites More sharing options...
