Snopczynski Posted April 30, 2009 Report Share Posted April 30, 2009 someone use "custom timing map" on his dynatek? or everybody use pre-set curve What does this mean??????????????? I use custom made timing maps. Quote Link to comment Share on other sites More sharing options...
3SGTE Posted May 1, 2009 Author Report Share Posted May 1, 2009 What does this mean??????????????? I use custom made timing maps. it's about homemade setting not curve 1 - 2 or 3 Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 1, 2009 Report Share Posted May 1, 2009 I have made some, but I like curve 3 alot. Quote Link to comment Share on other sites More sharing options...
3SGTE Posted May 2, 2009 Author Report Share Posted May 2, 2009 so dynatek is made for fine tuning timing only... is it not made for remplace completely timing plate Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 2, 2009 Report Share Posted May 2, 2009 so dynatek is made for fine tuning timing only... is it not made for remplace completely timing plate Where are you getting this stuff? You need to spell and grammar check yourself. Its hard trying to figure out what your saying or asking. I have no clue what your getting at with that last post. Quote Link to comment Share on other sites More sharing options...
3SGTE Posted May 3, 2009 Author Report Share Posted May 3, 2009 Where are you getting this stuff? You need to spell and grammar check yourself. Its hard trying to figure out what your saying or asking. I have no clue what your getting at with that last post. sorry I'm read and listen english... so my write is very bad and I'm worse for talk...lol I come from french country I start a thread in last resort There is not a lot of subject which deals of dynatek I retry... The dynatek can replace completely timing plate? Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted May 3, 2009 Report Share Posted May 3, 2009 an aftermarket timing plate replace's your non adjustable standard one. With elongated holes so you can move the sensor around the pick up to advance and retard your timing. a dynatek or other aftermarket cdi, replaces your cdi unit and instead of advancing/retarding the time mechanicly it does it electronicly threw a "map" that has points of advance and retard through the rev range. i choose to go with the adjustable cdi instead so i didnt have to pull shit apart to adjust my timing. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted May 3, 2009 Report Share Posted May 3, 2009 an aftermarket timing plate replace's your non adjustable standard one. With elongated holes so you can move the sensor around the pick up to advance and retard your timing. a dynatek or other aftermarket cdi, replaces your cdi unit and instead of advancing/retarding the time mechanicly it does it electronicly threw a "map" that has points of advance and retard through the rev range. i choose to go with the adjustable cdi instead so i didnt have to pull shit apart to adjust my timing. yes, If you program the cdi the dynatek will replace the timing plate for advance. Quote Link to comment Share on other sites More sharing options...
3SGTE Posted May 3, 2009 Author Report Share Posted May 3, 2009 yes, If you program the cdi the dynatek will replace the timing plate for advance. tank you so now have brand new unopen package trinity timing plate for sell Quote Link to comment Share on other sites More sharing options...
