dynatek FS vs timing plate
3SGTE
This is according to Cascade when I looked into buying one:
The Dyna has four standard curves. Curve 4 is the same as stock and 1-3 are more aggressive than stock. Mike told me it is fine to advance the timing plate to +4 as long as I did not use curve 3.
Using a timing plate at +4 and the Dyna on curve 4 is the same as +4 with the stock CDI. However, using a timing plate at +4 and curves 1,2, or 3 is NOT the same as stock.
Travis (Bigboybanshee) posted the curves on here a while ago, I will post them when I find them...
the dyna tek stock curve is still further advanced than stock and plus 4 on the plate is too much to run with the dynatek i did it and it was too much it didnt want to run for shit when it was hot and it also did run hotter. plus the fucking thing sounded like a race car with a with a huge cam in it really choppy. i knocked it back to plus 2 with stock curve and it seems to be better
Question was, can you do it? Answer is yes! Setup has to be right for it though.
Like I said, I run curve 3 with 4 degrees of advance added to it. You run the right compression, squish, porting, pipes, and octane, you too can be as cool as me. :biggrin:
It runs good that way. 5 degrees showed signs of detonation on the dyno. Yes, I did ride it to verify my findings.
Snopczynski 4-24-09 in a hole
Snopczynski side profile run 4-24-09 in a hole
