robert0762 Posted April 19, 2009 Report Share Posted April 19, 2009 (edited) So I was looking over my bike today just checking everything to make sure its in good shape bolts tight etc. My rear sprocket is wearing on the side. You can see how the chain is cutting into it. Are there supposed to be washers between the sprocket and hub? I I put some will it be ok. I'm pretty sure everthing is straight Edited April 19, 2009 by robert0762 Quote Link to comment Share on other sites More sharing options...
shee4speed Posted April 19, 2009 Report Share Posted April 19, 2009 Is your axle lined up properly?There is no washers there. Quote Link to comment Share on other sites More sharing options...
robert0762 Posted April 19, 2009 Author Report Share Posted April 19, 2009 (edited) Stock axle swinger and carrier.New bearings in carrier and swinger. Yes the sleeve is between the bearings Edited April 19, 2009 by robert0762 Quote Link to comment Share on other sites More sharing options...
fastbanshee8 Posted April 19, 2009 Report Share Posted April 19, 2009 That's fine, but did you make sure both adjustment bolts on the carrier are adjusted the same? If the carrier is crooked, the sprocket will wear on one side, or the other. Quote Link to comment Share on other sites More sharing options...
