manny 2004 banshee Posted April 18, 2009 Report Share Posted April 18, 2009 my compression was at 105 psi. Somebody said that i would need a new top end soon. Does anybody know at what psi i would need a new top end? Quote Link to comment Share on other sites More sharing options...
AKheathen Posted April 18, 2009 Report Share Posted April 18, 2009 my compression was at 105 psi. Somebody said that i would need a new top end soon. Does anybody know at what psi i would need a new top end? that may be. ideally, you want 120-130 at sea level, but the readings can be off due to elevation, method, and the tester that you're using. 5 psi or more difference, on the other hand; it's time for some work Quote Link to comment Share on other sites More sharing options...
banshee_terror_ Posted April 18, 2009 Report Share Posted April 18, 2009 umm your good id rebuild at 90 or like a 7psi or so diffrence but ak is right it depends on how you did the test and with what tester Quote Link to comment Share on other sites More sharing options...
manny 2004 banshee Posted April 18, 2009 Author Report Share Posted April 18, 2009 umm your good id rebuild at 90 or like a 7psi or so diffrence but ak is right it depends on how you did the test and with what tester well at the moment there is a 5 psi difference its at 105 on the right and 100 on the left Quote Link to comment Share on other sites More sharing options...
johnny boy Posted April 18, 2009 Report Share Posted April 18, 2009 well at the moment there is a 5 psi difference its at 105 on the right and 100 on the left just curious are you holding the throtle wide open while you are kicking it over?? Quote Link to comment Share on other sites More sharing options...
manny 2004 banshee Posted April 18, 2009 Author Report Share Posted April 18, 2009 just curious are you holding the throtle wide open while you are kicking it over?? no i start off with no gas, then if it doesn't turn on i open it some, then i give it all if it doesn't turn on Quote Link to comment Share on other sites More sharing options...
johnny boy Posted April 18, 2009 Report Share Posted April 18, 2009 no i start off with no gas, then if it doesn't turn on i open it some, then i give it all if it doesn't turn on when you are doing a compression test you are suppose to hold the throtle wide open while you are kicking it over till the needle stops moving..thats what i was asking..just curious Quote Link to comment Share on other sites More sharing options...
swrbansheeboy Posted April 18, 2009 Report Share Posted April 18, 2009 yes, when doing a compression check you need to hold the throttle wide open. also, what type of set up are you running? if you have a stone stock engine then 105 isn't too bad, if your running a cool head with 17cc domes then 105 sucks and it's time for a rebuild..... Quote Link to comment Share on other sites More sharing options...
manny 2004 banshee Posted April 18, 2009 Author Report Share Posted April 18, 2009 yes, when doing a compression check you need to hold the throttle wide open. also, what type of set up are you running? if you have a stone stock engine then 105 isn't too bad, if your running a cool head with 17cc domes then 105 sucks and it's time for a rebuild..... its bone stock Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted April 18, 2009 Report Share Posted April 18, 2009 mods dont matter. hold it WOT and kicked the hell out of it till it dont go no more. Unscrew it and do it again to insure it had a good seal. Quote Link to comment Share on other sites More sharing options...
