mounting tires ?
I use just i light coating of tire slime. Or if i don't have that at the time, i just use a light coating of wheel bearing grease :thumbsup:
Yes, Dont use tire soap to mount them.
Use water only.
Place a wratchet strap on the outer tread area around the tire and tighten it to help you seat the bead on the rim while you air it up.
Good luck.
I usually go to discount tire for $4.50 per tire its cheap
