Banshee won't start
recently my quad started backfiring. So i found a problem in the carb and i fixed that. Then it wouldn't turn on unless if i roll started it but it would still turn off it i didn't rev it and it would also flood. I changed one of the tors because the idle screw on it was broken and i thought that the idle would be the problem but it wasn't. I got it to turn on by roll starting it but it backfired right as it turned on and it turned off after around a minute. Then it wouldn't turn back on so what could be the problem. Please help because I'm only 14 and my parents want me to try and fix it myself before we take it to a shop. :thanks:
mine had similar problems to that when i had the tors, i bought the eliminator kit and it seemed to solve the problem. the tors are nothing but problems anyways. they are garbage.
I'm guessing you have plenty of gas in her. How do the plugs look? The two carbs are connected with a choke tube,is that in place?How is your airfilter?clean I hope. Make sure there are no leaks in the intake boots.
Just bought new NGK spark plugs, it has gas, cleaned the carbs and they are connected, and i cleaned out the air filter.
