Wildcardracing Posted April 11, 2009 Report Share Posted April 11, 2009 Pull your clutch cover and check the discs and steels, install 3 HD springs and redo your plug chop. I would also say if you're looking for more of a mid to top hit and a lot more power you need to consider some CPI or Shearer pipes instead of the FMF's. Quote Link to comment Share on other sites More sharing options...
Darthwall Posted April 11, 2009 Report Share Posted April 11, 2009 Pull your clutch cover and check the discs and steels, install 3 HD springs and redo your plug chop. I would also say if you're looking for more of a mid to top hit and a lot more power you need to consider some CPI or Shearer pipes instead of the FMF's. I would second this! when I got my 4mil put together I had kinda the same thing going I was running LRD's on a drag port it had decent bottom to mid but when it hit around 5k or so the power just kinda came or gradually. I ended up buying a set of CPI's put those on there and it improved ALOT! it was a night and day difference but a clutch is alot cheaper if you can get away with it Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 11, 2009 Report Share Posted April 11, 2009 i can tell you right now that main is too big. you should be closer to 160. Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted April 11, 2009 Report Share Posted April 11, 2009 If you get a new clutch i would install a pancake pusher as well since your going to be disassembling it anyway. Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted April 11, 2009 Report Share Posted April 11, 2009 If you get a new clutch i would install a pancake pusher as well since your going to be disassembling it anyway. good advice right there :thumbsup: Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted April 11, 2009 Report Share Posted April 11, 2009 Really disappointed or my clutch is slipping, New FAST dune port Just reassembled my Banshee. New FAST dune port, 35PWKs, +4 timing, 20cc domes, stock stroke, V3s, pump gas, 155psi and 1300 ft. I have done a plug chop, sync'd carbs and are jetted pretty close to perfect(165 mains)(middle clip on needle). Engine is fully broken in with about 4 tanks of fuel. Seems like it has real deceit low end power than it makes a lot of noise and revs like hell but it seems to have a flat spot in the power then it will finally come on. It will barely out drag my wifes 01 craptor. I hope my clutch is slipping, but it is slipping in mid range. I guess I will try a new clutch from Jeff and hope it gets better. Just not the power rush I expected. Will a clutch slip like this in mid range? I know it is porbably a dumb question because I am still running a low hour 05 stock clutch. If not I think I am ready for a 4mil and a cub. I am afraid my buddies 525 outlaw will smoke me. How much more power would I gain from changing domes and running race fuel? Thanks for any ideas. Wow, All you have to do Gary is give me a call and im here to help. If those cylinders wont smoke the competition i will buy them back! I could sell people my 125 hp cub off my personal bike and if they cant get power to the ground it wont do any good. Quote Link to comment Share on other sites More sharing options...
flotek Posted April 11, 2009 Report Share Posted April 11, 2009 other than your clutch i would say your mains sound big ,wrong pipes for adune port and the carbs are pretty big for a stock stroke dune pumper Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 11, 2009 Report Share Posted April 11, 2009 Really disappointed or my clutch is slipping, New FAST dune port Wow, All you have to do Gary is give me a call and im here to help. If those cylinders wont smoke the competition i will buy them back! I could sell people my 125 hp cub off my personal bike and if they cant get power to the ground it wont do any good. jeff, i seriously doubt this has anything to do with your work. 97% of the time the user doesnt know how to set up his bike. i dont think this time is any different. the guy states his jetting is almost perfect at 165 mains and doesnt even state his pilot. well thats BS. ive run 33, 35 and 39mm pwk on a wide variety of motors and ive never settled on 165 mains. 162 is the highest ive ever been and its usually about 158 to 160. this guy isnt that far from me so theres no reason his jetting should be that far off. i say jetting is off, too much tire pressure for the dragging surface and a guy who doesnt know how to ride.. its irritating when someone instantly blames a builder because he doesnt know what he doing. then instead of calling said builder, he jumps on the forums and says hes disappointed in the work. all bullshit if you ask me. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted April 11, 2009 Report Share Posted April 11, 2009 I did the cylinders but he has several other issues we are getting worked out. Quote Link to comment Share on other sites More sharing options...
bansheefreak Posted April 13, 2009 Report Share Posted April 13, 2009 Just reassembled my Banshee. New FAST dune port, 35PWKs, +4 timing, 20cc domes, stock stroke, V3s, pump gas, 155psi and 1300 ft. I have done a plug chop, sync'd carbs and are jetted pretty close to perfect(165 mains)(middle clip on needle). Engine is fully broken in with about 4 tanks of fuel. Seems like it has real deceit low end power than it makes a lot of noise and revs like hell but it seems to have a flat spot in the power then it will finally come on. It will barely out drag my wifes 01 craptor. I hope my clutch is slipping, but it is slipping in mid range. I guess I will try a new clutch from Jeff and hope it gets better. Just not the power rush I expected. Will a clutch slip like this in mid range? I know it is porbably a dumb question because I am still running a low hour 05 stock clutch. If not I think I am ready for a 4mil and a cub. I am afraid my buddies 525 outlaw will smoke me. How much more power would I gain from changing domes and running race fuel? Thanks for any ideas. well did you getting going??? figure out if .... your tires was bald,clutch was bad?? jetting off? Quote Link to comment Share on other sites More sharing options...
Gshock Posted April 13, 2009 Author Report Share Posted April 13, 2009 (edited) well did you getting going??? figure out if .... your tires was bald,clutch was bad?? jetting off? Ordered new clutch kit with 5 HD springs, new pancake bearing, new modded shift star, I had new 18" turf tamers on but ordered a new set of Ohtsu radials, and ordered longer carb top adjusters with lighter springs. Will drop mains down to 160 and do another plug chop and see what happens. (maybe go lower-just don't want to have a melt down) Exhaust is next on my list. Edited April 13, 2009 by Gshock Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted April 14, 2009 Report Share Posted April 14, 2009 Ordered new clutch kit with 5 HD springs, new pancake bearing, new modded shift star, I had new 18" turf tamers on but ordered a new set of Ohtsu radials, and ordered longer carb top adjusters with lighter springs. Will drop mains down to 160 and do another plug chop and see what happens. (maybe go lower-just don't want to have a melt down) Exhaust is next on my list. You sure you didn't get 6 HD springs? Quote Link to comment Share on other sites More sharing options...
Gshock Posted April 14, 2009 Author Report Share Posted April 14, 2009 You sure you didn't get 6 HD springs? yes I meant 6 Quote Link to comment Share on other sites More sharing options...
wesw Posted April 14, 2009 Report Share Posted April 14, 2009 where is polk missouri at??? Quote Link to comment Share on other sites More sharing options...
moneybags Posted April 14, 2009 Report Share Posted April 14, 2009 i can tell you right now that main is too big. you should be closer to 160. I would agree, I had a 4mill dune and play port from Jeff,185 PSI, 35 PWK's and only ran 168's and 48 poilets at sea level. Quote Link to comment Share on other sites More sharing options...
