b-nasty Posted April 8, 2009 Report Share Posted April 8, 2009 Getting my motor put back together, 4mil crank with 68 cub cylinders. When i bought the cylinders i got a cool head and the domes the guy was running with it. The domes are 19cc and he was running gas through it. Does it matter what dome you use on gas or alky. What do you guys think i should be running for a dome. thanks Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 8, 2009 Report Share Posted April 8, 2009 I run 20 cc gas domes with alky on mine, and it runs pretty good. Not sure how much more benefit I'd get out of changing to alky domes. Quote Link to comment Share on other sites More sharing options...
al'boutmykakgnamrybetycrka Posted April 9, 2009 Report Share Posted April 9, 2009 personally, the race fuels out now are as good if not better than alky. Whats your reason for running alcohol, j/w Quote Link to comment Share on other sites More sharing options...
al'boutmykakgnamrybetycrka Posted April 9, 2009 Report Share Posted April 9, 2009 personally, the race fuels out now are as good if not better than alky. Whats your reason for running alcohol, j/w. Plus you should be able to run lower than 19cc w/ alk Quote Link to comment Share on other sites More sharing options...
moneybags Posted April 10, 2009 Report Share Posted April 10, 2009 personally, the race fuels out now are as good if not better than alky. Whats your reason for running alcohol, j/w. Plus you should be able to run lower than 19cc w/ alk I would not count on that. Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted April 10, 2009 Report Share Posted April 10, 2009 I'd get some more domes cut for alky, there slightly different than gas domes. I think the edges on gas domes are rounded off and alky domes are squared off. Let me see if i can find that thread about domes real fast. Quote Link to comment Share on other sites More sharing options...
scottzimmerman Posted April 10, 2009 Report Share Posted April 10, 2009 alky likes a narrower squish band. need help got prodesign cool head t5 pro flow stock carbs -tors stock juggs cool head came with 19cc domes want to run pump gas should i go with 20 or 21cc domes? Quote Link to comment Share on other sites More sharing options...
shanYE west Posted April 10, 2009 Report Share Posted April 10, 2009 I would not count on that. Alky is good for 10-13% increase in HP over race fuel... So I'm gonna have to agree with Moneybags on this one. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 10, 2009 Report Share Posted April 10, 2009 personally, the race fuels out now are as good if not better than alky. Whats your reason for running alcohol, j/w I also disagree with that statement. Maybe some oxygenated, or exotic race fuels are close to alky, but a hell of a lot harder on the motor, run a lot hotter, and are $$$$$$. Quote Link to comment Share on other sites More sharing options...
