Black01Shee Posted April 6, 2009 Report Posted April 6, 2009 OK im having an idle problem and it all started when i decided to unscrew that 8mm bolt inside the throttle assembly that holds all the throttle plates together. After i retightened it my bike only idles sometimes and when it doesnt i snap the throttle a couple times and then itll idle fine again. I know its that damn little tors button inside the throttle assembly. I think its just not being pushed at the right time now when i let go off the throttle and makes the bike die. Heres a video so you can see what im talking about http://www.youtube.com/watch?v=Tismjml5NiE...re=channel_page What is the proper way that throttle assembly with that 8mm bolt needs to be adjusted to. Quote
1.6i Posted April 6, 2009 Report Posted April 6, 2009 (edited) get a tors removal kit and just get rid of it..simple as that... what are your mods..? Edited April 6, 2009 by 1.6i Quote
Black01Shee Posted April 6, 2009 Author Report Posted April 6, 2009 All i got is a Dynoprot 2 into 1 Pipe and Modquad 2 into 1 intake system No snorkel 260 mains. Quote
KaosBanshee44 Posted April 6, 2009 Report Posted April 6, 2009 TORS is a pain in the ass i would just get the removal kit and put the idle kit on as well and be good to go. Quote
