OK im having an idle problem and it all started when i decided to unscrew that 8mm bolt inside the throttle assembly that holds all the throttle plates together. After i retightened it my bike only idles sometimes and when it doesnt i snap the throttle a couple times and then itll idle fine again. I know its that damn little tors button inside the throttle assembly. I think its just not being pushed at the right time now when i let go off the throttle and makes the bike die. Heres a video so you can see what im talking about http://www.youtube.com/watch?v=Tismjml5NiE...re=channel_page
What is the proper way that throttle assembly with that 8mm bolt needs to be adjusted to.
get a tors removal kit and just get rid of it..simple as that...
what are your mods..?
Edited by 1.6i
