axlracing Posted April 4, 2009 Report Share Posted April 4, 2009 the guy i bought the banshee from said the carbs came from honda cr 250r they ae keihin flat slide carbs and say pj on them. Just trying to figure out what size they are honda changed there carbs quite a bit i think I know the later cr250r's had mikuni carbs?? thanks Quote Link to comment Share on other sites More sharing options...
bonbon Posted April 4, 2009 Report Share Posted April 4, 2009 Measure between the inside edges of the bore on the intake side of the carb. That will give you the size. Quote Link to comment Share on other sites More sharing options...
axlracing Posted April 4, 2009 Author Report Share Posted April 4, 2009 Measure between the inside edges of the bore on the intake side of the carb. That will give you the size. it s exactly 2 1/8 inch on the inside of the air filter side? Quote Link to comment Share on other sites More sharing options...
bonbon Posted April 4, 2009 Report Share Posted April 4, 2009 Sorry I meant the engine side of the carb, the smaller side. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 4, 2009 Report Share Posted April 4, 2009 I am going to take a stab and say they are 34's Here is the dimensions of the PJ carbs. http://www.keihin-us.com/am/products/pj.php Quote Link to comment Share on other sites More sharing options...
axlracing Posted April 4, 2009 Author Report Share Posted April 4, 2009 I am going to take a stab and say they are 34's Here is the dimensions of the PJ carbs. http://www.keihin-us.com/am/products/pj.php 1 3/8" on the inside Quote Link to comment Share on other sites More sharing options...
bonbon Posted April 4, 2009 Report Share Posted April 4, 2009 That would make them 34mm PJ's Quote Link to comment Share on other sites More sharing options...
axlracing Posted April 4, 2009 Author Report Share Posted April 4, 2009 That would make them 34mm PJ's alrigh great I have one more question my air screw on the side of the carb is only out 1/2 turn from closed and when the quad is cold and i start it the engine revs preety bad for a second or two shout i richen my pilot jet , thanks Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 4, 2009 Report Share Posted April 4, 2009 Yea I would go up a pilot size and reset the air scews at 1.5 turns out and tune it from there. If your at .5 or under then up the pilot and reset the air scew. If your at 3 or over then drop the pilot and reset the air scew. josh Quote Link to comment Share on other sites More sharing options...
axlracing Posted April 4, 2009 Author Report Share Posted April 4, 2009 Yea I would go up a pilot size and reset the air scews at 1.5 turns out and tune it from there. If your at .5 or under then up the pilot and reset the air scew. If your at 3 or over then drop the pilot and reset the air scew. josh thanks Quote Link to comment Share on other sites More sharing options...
