SLORYDER Posted April 2, 2009 Report Share Posted April 2, 2009 I have 3 heavy duty clutch springs I was wondering if it would be safe to run only those 3 with my lockout or if I should get all 6 in there somehow and if so how the he'll do you compress them enough to start the bolts Thanks Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted April 2, 2009 Report Share Posted April 2, 2009 I run 6 OEM springs with mine. Quote Link to comment Share on other sites More sharing options...
uwenr Posted April 2, 2009 Report Share Posted April 2, 2009 I have 3 heavy duty clutch springs I was wondering if it would be safe to run only those 3 with my lockout or if I should get all 6 in there somehow and if so how the he'll do you compress them enough to start the bolts Thanks I ran 6 hd springs in mine and it was too much went to 3 stock and 3 hd Quote Link to comment Share on other sites More sharing options...
kayjay_2002 Posted April 2, 2009 Report Share Posted April 2, 2009 everyone i know stagger them 3 heavy and 3 oem Quote Link to comment Share on other sites More sharing options...
spurdy Posted April 2, 2009 Report Share Posted April 2, 2009 I run 3 oem springs. I start with a longer bolt in 2 positions opposing each other. Use those to compress slightly until I can start the other 4 original bolts. Once those are threaded in a fair amount I remove the long ones and replace with the last 2 original bolts and tightened accordingly. SP Quote Link to comment Share on other sites More sharing options...
TNTS355 Posted April 2, 2009 Report Share Posted April 2, 2009 I have 3 heavy duty clutch springs I was wondering if it would be safe to run only those 3 with my lockout or if I should get all 6 in there somehow and if so how the he'll do you compress them enough to start the bolts Thanks With the way the lockout was designed you do not need HD springs. I tried 3 HD and 3 OEM. I went back to all OEM. I think that it works better. You need a little slip coming out of the hole. Quote Link to comment Share on other sites More sharing options...
spurdy Posted April 2, 2009 Report Share Posted April 2, 2009 With the way the lockout was designed you do not need HD springs. I tried 3 HD and 3 OEM. I went back to all OEM. I think that it works better. You need a little slip coming out of the hole. My thoughts exactly. The centrifugal force is providing the pressure, not the springs. It is hard enough to get a little slipping from the lockout to begin with, no reason to over work your forearm in the process. SP Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted April 3, 2009 Author Report Share Posted April 3, 2009 I run 3 oem springs. I start with a longer bolt in 2 positions opposing each other. Use those to compress slightly until I can start the other 4 original bolts. Once those are threaded in a fair amount I remove the long ones and replace with the last 2 original bolts and tightened accordingly. SP So you only run the three own springs and that's it right?seem to work well? Quote Link to comment Share on other sites More sharing options...
spurdy Posted April 3, 2009 Report Share Posted April 3, 2009 So you only run the three own springs and that's it right?seem to work well? Shit! Sorry, I meant 6 oem springs. No HD springs. SP Quote Link to comment Share on other sites More sharing options...
Darthwall Posted April 3, 2009 Report Share Posted April 3, 2009 just run the oem ones on it I tried running 6 hard springs works great harder to pull the lever back and then the 3 oem and 3 hard same results little easyier to pull the clutch back and finaly oem's and they do the same thing. the fingers on the lock out are what gives the results your looking for no sence in wasting money Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 3, 2009 Report Share Posted April 3, 2009 you dont need HD springs at all. i run all OEM in my 10mm cub. Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted April 3, 2009 Author Report Share Posted April 3, 2009 so maybe it's not the best idea to leave out 3 springs? Quote Link to comment Share on other sites More sharing options...
SLORYDER Posted April 5, 2009 Author Report Share Posted April 5, 2009 so maybe it's not the best idea to leave out 3 springs? Bump Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 5, 2009 Report Share Posted April 5, 2009 so maybe it's not the best idea to leave out 3 springs? to only run 3 springs? hell fuck no. run all 6. Quote Link to comment Share on other sites More sharing options...
