Is Trans oil plus ok 2 run in my banshee?
i was just wondering if it was ok to run yamaha trans oil plus in the case on the side of my banshee or should i run some havoline 2 cycle oil in it. thx for the help oh btw its 20w40 trans oil, the guy at the 4 wheeler shop told me to put it in, just wanted to make sure.
Edited by chris hinds
i know alot of people run atf and have good luck with it but i have to agree with the idea of atf being designed to work with clutches and gears in car transmissions....
i personaly run redline shockproof gear oil, i know it's expensive ($13 a quart) but i know it works well and it coats everything like power punch. it's a bitch to clean up when splitting cases but i know it's doing it's job, plus i can get a full season out of 2 quarts vs. swapping out atf after every ride.
i'm not trying to sway anyones ideas of what to run for oil, just stating what i run and why.
i actualy used to run gear saver then started running the redline because of a story my builder told me about one of there drag bikes that got re-built and the case never got filled, after several runs they realized that the bike had no oil in it. they were running the redline and nothing got chewed up so that was enough for me to switch and i have had no problems with it since switching.
it was hard to go from something i was running that i had no problems with to something else i had nothing more than my builders word that it worked, kinda like going from running "insert your brand of premix here" to running amsoil saber. kind of hard to believe what your hearing is true untill you make the jump and run it for yourself.
basicly there are many proven oils to use, you just need to figure out how much you want to spend and how often you want to change them...
Edited by swrbansheeboy
