pabansheematt Posted April 2, 2009 Author Report Share Posted April 2, 2009 Just started having a problem a few weeks ago. The bike wont shift into 3rd gear unless i'm going slow. If I ride it slow and shift, it goes in and stays in. If I try to shift from 2nd to 3rd on a hill it goes into between 2 gears and makes grinding noise. So I had a known good used trans. I replaced all shift forks and all gears that had anything to do with 3rd. Does the same thing. Anyone have any ideas? I believe I found the problem. The end of the shift shaft is loose and sloppy. You can actually see marks on it were it was rubbing the shift star. Quote Link to comment Share on other sites More sharing options...
