Stupid Banshee
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
Where do you have your clutch arm set at? Got a picture of that? Is it close to the little pointer on the case? I usually run my cable in between the radiator and the hoop for the steering stem. The tank is pretty tight against the backside of it on my bike. Don't think that will help your problem though.
its close, just a little bit off. not near enough for this to happen though, i have the rod all the way back. my adjuster gets watched very closely now. the nut came off the first day i had it running and the clutch chewed it up. didnt hurt anything, just a couple clutch teeth needed filed.
You're learning all kinds of good stuff the hard way. Builds character and shit. Good for you man. :biggrin:
so, apparently there is a difference between the 02 and up and 01 and down banshee throttle cables. they took it back.
your running the clutch and throttle cables the wrong way.they need to go between the radiator and the stem support.there are 2 hooks that bolt with the stem mount,thats were you cables need to go through.and there is no diffrence between a 87 and a 06 banshee clutch cable
Edited by tony cub
according to the dealer there is.
