oneslowshee Posted March 25, 2009 Report Share Posted March 25, 2009 ok so i bought an override, and i just want to make sure that i am putting the shift forks in the right spot on the non sprocket gear set. there are 2 notches and it looks like it can go and looking at it from the top does it go on the left or right slot on a override? Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted March 25, 2009 Report Share Posted March 25, 2009 umm.. the counter sprocket shaft (gear set that the sprocket bolts to) gear set gets 2 shift forks (toward the rear opf the motor) the front gear set (closest to the crank) gets 1 shift fork.. pay attention, not all the shift forks are the same.. where did u get the overide?? mine came with full directions.. its just as easy as setting a stock tranny in place, except ading the springs for the shift forks.. all i needed was a picture whowing which spring went where.. hope that helps, if not reword your question so i can understand what you are asking a little better.. Quote Link to comment Share on other sites More sharing options...
oneslowshee Posted March 25, 2009 Author Report Share Posted March 25, 2009 umm.. the counter sprocket shaft (gear set that the sprocket bolts to) gear set gets 2 shift forks (toward the rear opf the motor) the front gear set (closest to the crank) gets 1 shift fork.. pay attention, not all the shift forks are the same.. where did u get the overide?? mine came with full directions.. its just as easy as setting a stock tranny in place, except ading the springs for the shift forks.. all i needed was a picture whowing which spring went where.. hope that helps, if not reword your question so i can understand what you are asking a little better.. ok its the gear set the only gets 1 shift fork i am just curious where the shift fork rides on the gear set. it looks like there are 2 places it could posibly sit, i bought it used and its a non dubeable so no instructions or springs.... Quote Link to comment Share on other sites More sharing options...
