jaydun323 Posted March 22, 2009 Report Share Posted March 22, 2009 My mods are Fatty pipes, core 2 tips, KnN pods no outer wears, stock carbs with TORS removed. Jetting is 310 mains, 27.5 pilots, thanks to Jeff at FAST And my elevation is about 300ft. Problem is when its cold/or first start in a about an hour my shee will only start if i pull my KnN pods off and cover the carbs with my hand until i get a little gas on them, then it runs great no problems at all, once its warmed up i can shut it off and start it first kick. I dont get it WTF is going on? Anyone else ever have this problem? Any help would be greatly appriciated. Thanks in advance, Justin Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted March 22, 2009 Report Share Posted March 22, 2009 sounds like its too lean on the pilots. try adjusting your air screws. Quote Link to comment Share on other sites More sharing options...
jaydun323 Posted March 22, 2009 Author Report Share Posted March 22, 2009 air screws are 1.5 turns out Quote Link to comment Share on other sites More sharing options...
AKheathen Posted March 23, 2009 Report Share Posted March 23, 2009 check that your float bowls are on the right side. one hase a little brass bead in the side, which goes to the choke side carb Quote Link to comment Share on other sites More sharing options...
jaydun323 Posted March 23, 2009 Author Report Share Posted March 23, 2009 bowls are correct Quote Link to comment Share on other sites More sharing options...
jaydun323 Posted March 23, 2009 Author Report Share Posted March 23, 2009 come on guys anybody else. i would really appreciate the help. thanks Justin Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted March 24, 2009 Report Share Posted March 24, 2009 do you have port work done? and what is your altitude Quote Link to comment Share on other sites More sharing options...
hyperlite33 Posted March 24, 2009 Report Share Posted March 24, 2009 The problem lies in your pilot circuit...what size pilots do you have in there? Quote Link to comment Share on other sites More sharing options...
BUILDER Posted March 24, 2009 Report Share Posted March 24, 2009 The problem lies in your pilot circuit...what size pilots do you have in there? He says in his post 27.5 pilots. Your pilots should be big enough for your mods and youe elevation. Have you had the carbs off and cleaned the pilot circuit out really well? If you have done that and you crabs are in good shape i would do a compression test on it and see were you are at? Quote Link to comment Share on other sites More sharing options...
Shags450 Posted March 24, 2009 Report Share Posted March 24, 2009 My banshee is having the cold start problem also, I took my filters off and held my hand over the carbs and it started right up.. wtf!!! Im taking my carbs off now and giving them a good cleaning ill let you know what my experinces are. Quote Link to comment Share on other sites More sharing options...
jaydun323 Posted March 24, 2009 Author Report Share Posted March 24, 2009 Carbs have been thuroughly clean multipull times, pilot circut is clean, ued a little piece of afety wire from work, Air Force work on planes. No port work, and compresion is 120 right and 110 left, i know its 10 off but damn its not like it 80 or 90. Quote Link to comment Share on other sites More sharing options...
Shags450 Posted March 24, 2009 Report Share Posted March 24, 2009 Carbs have been thuroughly clean multipull times, pilot circut is clean, ued a little piece of afety wire from work, Air Force work on planes. No port work, and compresion is 120 right and 110 left, i know its 10 off but damn its not like it 80 or 90. I just took my carbs off and cleaned them aswell, I have a 300 main 25 pilot and im having the same problem since I added the vforce 3 reeds and cool head and removed air box for new filters. I only have to cover 1 carb to get mine started. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted March 24, 2009 Report Share Posted March 24, 2009 Close your airscrews in to 1/2 turn out and see if that helps. It is definately a lean pilot circuit for both of you. Are you both Positive the bowls are on the correct side and the pilot passage and jets are completely clean. Should be able to see light through them. Compressed air is the best way to get the pilot and choke passages in the carbs and bowls. Quote Link to comment Share on other sites More sharing options...
Shags450 Posted April 19, 2009 Report Share Posted April 19, 2009 Carbs have been thuroughly clean multipull times, pilot circut is clean, ued a little piece of afety wire from work, Air Force work on planes. No port work, and compresion is 120 right and 110 left, i know its 10 off but damn its not like it 80 or 90. did you get your problem situated? I havnt yet >.< Quote Link to comment Share on other sites More sharing options...
AKheathen Posted April 20, 2009 Report Share Posted April 20, 2009 also, coke tube, choke plunger o-ring, and the cable retainers can cover the hole in the top of the slides if the are bolted on backwards. tune your airscrews richer, and check for airleaks. Quote Link to comment Share on other sites More sharing options...
