dbdragracing Posted April 3, 2009 Report Share Posted April 3, 2009 How much wider do the YFZ arms make the Banshee? Do you have to buy long rear axles? My suspension is stock and I do a lot of trail riding and some drag racing...I need some suspension help! Quote Link to comment Share on other sites More sharing options...
bode1 Posted April 3, 2009 Report Share Posted April 3, 2009 What do you guys use to trim the a-arms with? Do all yfz shocks have high and low speed adjustments, or just the SE editions? Quote Link to comment Share on other sites More sharing options...
2003LimitedBanshee Posted April 4, 2009 Report Share Posted April 4, 2009 What do you guys use to trim the a-arms with? Do all yfz shocks have high and low speed adjustments, or just the SE editions? Personally, I have a jig that I built for cutting the arms down using my abrasive wheel chopsaw. This makes sure that I can consistently reproduce the same results and fit each and every time. Then I dress them up, so there are no hangers, burrs etc. As far as shocks go, the standard YFZ shocks only have single speed compression and single speed rebound adjustment (preload too). The SE shocks, from 06-08 models (?) had hi and low speed compression adjustment, instead of simple compression adjustment. NOW, if you are ambitious, you can run make the YFZ450R shocks work. I haven't got the chance to ride it yet, but I'm hopeful. Quote Link to comment Share on other sites More sharing options...
scottzimmerman Posted April 5, 2009 Report Share Posted April 5, 2009 Personally, I have a jig that I built for cutting the arms down using my abrasive wheel chopsaw. This makes sure that I can consistently reproduce the same results and fit each and every time. Then I dress them up, so there are no hangers, burrs etc. As far as shocks go, the standard YFZ shocks only have single speed compression and single speed rebound adjustment (preload too). The SE shocks, from 06-08 models (?) had hi and low speed compression adjustment, instead of simple compression adjustment. NOW, if you are ambitious, you can run make the YFZ450R shocks work. I haven't got the chance to ride it yet, but I'm hopeful. i broke a se shock today out with banshee dan can i fix it all thats there is the spring dont ride to good now lol please help Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted April 5, 2009 Report Share Posted April 5, 2009 What? Quote Link to comment Share on other sites More sharing options...
scottzimmerman Posted April 5, 2009 Report Share Posted April 5, 2009 What? the rod on the inside is gone can i replace that rod or do i need a new shock????? Quote Link to comment Share on other sites More sharing options...
BansheeDan Posted April 5, 2009 Report Share Posted April 5, 2009 the rod on the inside is gone can i replace that rod or do i need a new shock????? I Still dont understand how the rod in that shock broke..... I have never seen that happen ever. Dan Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted April 6, 2009 Report Share Posted April 6, 2009 Your going to need a new shock. Quote Link to comment Share on other sites More sharing options...
scottzimmerman Posted April 6, 2009 Report Share Posted April 6, 2009 that sucks do yo know where i can get 1 cheep trying to get a set of pipes and pods 2 be for haspin trip Quote Link to comment Share on other sites More sharing options...
