This is the way i want to go.
Ineedmoney
Ok this is the way i would like to go wiht my banshee.
I want a fast racing banshee that can still do open fields and shit.
So mx is perfect. i do jumps all the time.
What i would liek to know is some basics to MX
What pipes are good for mx
what engine?
what wheels?
what suspension?
ETC......
pipes, you want some low end pipes like pro circuits, fmf gnarlys, paul turner mids, etc.
engine- you want good low end so you should get a mx port for your cylinders, a adjustable timing plate with +4 timing and thats pretty much it for motor.
wheels- you want to get 20 or 19" front and 18 or 19" rear mx tires. some examples are holeshot mxr4, mxr6 razrmx's etc. and you could get them on just .160 rims or .190 for extra strength.
suspension- you want some aftermarket a-arms and shocks. i run wicked 2+1 a-arms. if your doing strictly mx and wide open trails you should get 3+1 a-arms. you should then get shocks like works, tcs, elka etc. also you should get a shorter swingarm for a smaller turning radius like a -1 or a -2. then you could revalve your rear shock and get it done from companys like pro pilot, tcs, works etc. or you can just get a brand new rear shock for almost $1000! hope this helped.
This helped alot thank you
I thought Pro Circuit pipes were and all around pipe like T5's/T6's?
hey cajun
anyway the guy snopkoywsski (spelling obviously) has done lots of dyno testing on different setups and i believe he said the best pipe for low-mid was the Pro circuit , even better than the PT mids
  • 1 month later...
yes, at actual races sometimes there are restrictions on front end width, but open practice is pretty much outlaw.
suspension is very important.
might even look into long travel.
on the rear a g force axle is a cheap mod to have not mentioned.
having torque out of corners is always good, so a 4-7mm stoker helps
higher compression
timing advance +4-7 deg
boyeseen 2 stage carbon fibers or vf2`s are good
without porting Id go with PT mids
with pv and porting pro circs, dmc or equivelent
-2 swinger
bead lock rims, hypers if you can afford. esp on rear.
low raduis tires ~18 on rear 20 up front mxr6 in hard / meduim, gncc in med / loose.
steering stablizer or flex bars
28-30mm carbs. dep on porting. a smaller carb will make better low-mid velocity.
pods with outers. open box w k&n if mud or water is involved
a good clutch actuation system unless you like arm pump.
if you have performance clutch springs try and stager hiperf with stock.
GOOD PRO PEG NERFS!!!!!
front fenders cut
slotted/drilled rear rotors help in mud/water braking
skateboard grip tape on throttle
tether of course
13t drive gear
if your really into it a 250r geometry frame
if your any more serious than that get a 450
lots of racing decals
billet impeller and engine ice,... no air moves through a radiator full of others roosted mud and not alot of speed on a track.
That all I can think of for now?
  • 4 weeks later...
higher compression
-2 swinger
front fenders cut
tether of course
13t drive gear
dang man i think you basically covered it all
  • 11 months later...
Yup Fastrthnu pretty much covered it. -2 swingarms are a must. Good shocks. Id recommend a CMF aluminum airbox. Its bigger then stock and takes 2 34mm pod filters and changes your intake length which is supposed to work pretty good.
