b-nasty Posted March 16, 2009 Report Share Posted March 16, 2009 What size alky lectrons should i run on my 4 mill 421 banshee. thanks Quote Link to comment Share on other sites More sharing options...
oneslowshee Posted March 16, 2009 Report Share Posted March 16, 2009 What size alky lectrons should i run on my 4 mill 421 banshee. thanks i am going to be running 40 mm set up by packard. are you going to be running a pump or gravity feed? Quote Link to comment Share on other sites More sharing options...
b-nasty Posted March 16, 2009 Author Report Share Posted March 16, 2009 gravity, would 38mm be ok? Quote Link to comment Share on other sites More sharing options...
Koolguyson Posted March 16, 2009 Report Share Posted March 16, 2009 What size alky lectrons should i run on my 4 mill 421 banshee. thanks 38's Quote Link to comment Share on other sites More sharing options...
1996dragshee Posted March 16, 2009 Report Share Posted March 16, 2009 word...38s would be plenty.if you're going to gravity feed them you should get oversized bowls or just spend 55 and run a pump.Just a thought Quote Link to comment Share on other sites More sharing options...
Koolguyson Posted March 16, 2009 Report Share Posted March 16, 2009 word...38s would be plenty.if you're going to gravity feed them you should get oversized bowls or just spend 55 and run a pump.Just a thought A pump is definitely cheap insurance. Quote Link to comment Share on other sites More sharing options...
b-nasty Posted March 16, 2009 Author Report Share Posted March 16, 2009 Where and how do you hook up a pump. thanks Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 16, 2009 Report Share Posted March 16, 2009 I'd go 40's all day long. The most common way to use a fuel pump is drill your cylinder for a barb fitting (pulse/vacuum pumps) and plumb it in that way. The intake in front of the reeds is a good spot for the pulse/vaccum signal.... In Lectrons, you also need 3.3 needle and seat. If you use gravity fed needle and seats on a pump, it'll overpower their sealing and drip fuel all over. Quote Link to comment Share on other sites More sharing options...
oneslowshee Posted March 16, 2009 Report Share Posted March 16, 2009 I'd go 40's all day long. The most common way to use a fuel pump is drill your cylinder for a barb fitting (pulse/vacuum pumps) and plumb it in that way. The intake in front of the reeds is a good spot for the pulse/vaccum signal.... In Lectrons, you also need 3.3 needle and seat. If you use gravity fed needle and seats on a pump, it'll overpower their sealing and drip fuel all over. i would go with gravity just drill out your gas cap, run 3/8 fuel line and oversized bowls and you should be fine... Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted March 27, 2009 Report Share Posted March 27, 2009 40 HVs, Remember the lectrons are actually smaller than they are listed and sold as which is fine. A 40 is a couple mm smaller than 40mms. My 421 pulled some real nice hp and torque #'s on 40 HVs but if you are dragging only or using alky I'd use 39 or 41.5 pwks. The tuning ease of lectrons is nice tho. Quote Link to comment Share on other sites More sharing options...
