twizted269 Posted March 15, 2009 Report Share Posted March 15, 2009 what causes the plugs to back out? i locked them so tight i was worried about stipping the domes out. does anyone use locktite on them? im gonna get the bracket that holds them both but just wanted to know. Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted March 15, 2009 Report Share Posted March 15, 2009 spark plugs backing out mean your detonating which means you VERY lean. and you need to upjet before you melt down the motor. what mods, jetting, elevation...etc Quote Link to comment Share on other sites More sharing options...
twizted269 Posted March 15, 2009 Author Report Share Posted March 15, 2009 (edited) spark plugs backing out mean your detonating which means you VERY lean. and you need to upjet before you melt down the motor. what mods, jetting, elevation...etc all mods are in my sig. jetting is 300 mains, 30 pilots, stock needle position, running 93 octane with 150 psi compression. the elevations is between 500 to 1000. plugs burning golden brown. its the 96. Edited March 15, 2009 by twizted269 Quote Link to comment Share on other sites More sharing options...
tony cub Posted March 15, 2009 Report Share Posted March 15, 2009 (edited) what causes the plugs to back out? i locked them so tight i was worried about stipping the domes out. does anyone use locktite on them? im gonna get the bracket that holds them both but just wanted to know. dont get the bracket,thats only housing a problem....plugs back out for a few resons. 1 detonation 2 damaged threads on domes 3 crank may be out of balance Edited March 15, 2009 by tony cub Quote Link to comment Share on other sites More sharing options...
bansheefreak Posted March 15, 2009 Report Share Posted March 15, 2009 i wouldnt get the plug lock they sell... if its detonating and backing out you wanna know it.. that lock could cost you lots of money in repairs when the motor burns up.. are you doing a wot plug chop??? Quote Link to comment Share on other sites More sharing options...
twizted269 Posted March 15, 2009 Author Report Share Posted March 15, 2009 dont get the bracket,thats only housing a problem....plugs back out for a few resons. 1 detonation 2 damaged threads on domes 3 crank may be out of balance i was thinking maybe the threads also. crank only has about 4 tanks on it so i wouldnt think that. also it never did this with the stock head. only since the cool head was installed. maybe compression change? went up 40 psi Quote Link to comment Share on other sites More sharing options...
tony cub Posted March 15, 2009 Report Share Posted March 15, 2009 i was thinking maybe the threads also. crank only has about 4 tanks on it so i wouldnt think that. also it never did this with the stock head. only since the cool head was installed. maybe compression change? went up 40 psi whats your squish at?? Quote Link to comment Share on other sites More sharing options...
XxMeltIcexX Posted March 15, 2009 Report Share Posted March 15, 2009 i was thinking maybe the threads also. crank only has about 4 tanks on it so i wouldnt think that. also it never did this with the stock head. only since the cool head was installed. maybe compression change? went up 40 psi Whats your compression? Sounds like your detonating, need race gas in there. Quote Link to comment Share on other sites More sharing options...
twizted269 Posted March 15, 2009 Author Report Share Posted March 15, 2009 i havnt done a "plug chop". never have. allways went by the colot of the ceramic. i have no idea what the squish band is at either. i would asume stock with stock stroke crank and pistons. compression is a 150 psi which seems it should be fine for 93 octane. if not ill get another set of domes to lower it. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted March 15, 2009 Report Share Posted March 15, 2009 i would definately say detonation.. what size domes?? what is your timing at?? start by throwing more fuel and less timing at it.. get it safe, then start tuning it from there... check those plugs.. Quote Link to comment Share on other sites More sharing options...
twizted269 Posted March 15, 2009 Author Report Share Posted March 15, 2009 i would definately say detonation.. what size domes?? what is your timing at?? start by throwing more fuel and less timing at it.. get it safe, then start tuning it from there... check those plugs.. dome are 20cc with +4 timing. looking to go with 22cc soon. working out the kinks from the winter build is getting on my nerves lately. lol. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted March 15, 2009 Report Share Posted March 15, 2009 check and make sure all bases are covered.. make sure your flywheel key isn't sheared causing timing issues... i run 19cc domes and +5 timing on 93 pump gas no problems.. but im throwing a lot of fuel at it. my compression is about 160.. what plugs are you using?? Quote Link to comment Share on other sites More sharing options...
docjcwatson Posted March 15, 2009 Report Share Posted March 15, 2009 You could've stripped the threads when you were tightening down on those plugs. Are you tightening them with a correct size socket. Or are turning them with a wrench? Have you checked the plugs since this started? Quote Link to comment Share on other sites More sharing options...
twizted269 Posted March 15, 2009 Author Report Share Posted March 15, 2009 check and make sure all bases are covered.. make sure your flywheel key isn't sheared causing timing issues... i run 19cc domes and +5 timing on 93 pump gas no problems.. but im throwing a lot of fuel at it. my compression is about 160.. what plugs are you using?? im just running the standard br8es plug. what are the main causes for detonation? the only thing ive changed for this problem is the cool head. jetting was always pretty rich with the stock head. im pretty set on going to 22 cc domes and get it closer to stock compression. fly wheel key is also fine. checked that for another problem i had. Quote Link to comment Share on other sites More sharing options...
twizted269 Posted March 15, 2009 Author Report Share Posted March 15, 2009 You could've stripped the threads when you were tightening down on those plugs. Are you tightening them with a correct size socket. Or are turning them with a wrench? Have you checked the plugs since this started? i use a wrench for the plugs. i changed them out on the trail today and they look golden brown. Quote Link to comment Share on other sites More sharing options...
