first run 35mm
i just listed the rocket science forum. got my banshee to run but not idle. did the first run on it today, It was bad. When i gave it fu;ll throttle it fell on its face. so i kept riding it like that all day. i messed with the air screw and leaned it. it died and now wont start. whats my problem and how can i fix it? im running 50 pilots 150mains. toomey t5 1300 absl, dune port, im now thinking about taking it to my mechanic and paying 200-350 to get it dynoed,tuned,and jetted. any suggestions?
I'm running 150 mains as well, and I am at 4800'? sounds like you are way lean.
I just built a stock cylinder dune port motor with 35mmpwks,after he brought it back after break in I ended up at 48pilot,165 main at sea level,+4timing,t-5s,air box no lid
When a banshee doesnt run right and you keep riding it,you will melt the engine down. Especially if your lean.
your main needs to be up towards 160. id say try a 162 to be safe. pilot probably needs to be a 45 or 48.
hope you didnt lean it out and put a hole in the top of the piston.
did you do a WOT plug check at all?
the right plug was smoked white, the left side was honey brown. put new plugs in it, pulled the bowls off the mains were sittin in the bottom,ooopps! so i switched back to 168mains. I dont know. taking it to the mechanic on monday!
