TJScott Posted March 14, 2009 Report Share Posted March 14, 2009 So first time filing up the banshee with tranny fluid since im just now getting that far in the build, i saw 1500cm3, and mistaked it for 1500cc's. i poured in a little over 1200cc's of oil since thats all i had. i turned around and there was fluid everywhere, it was coming out of the hose that is supposed to route above the access panel by the water pump, i dont have an access panel btw. so i saw it was overfull and let it run out. i come back 20 minutes later, and its still dripping out. i check the dipstick and its a little under half. so why did it continue to drain? is it even supposed to be leaking? Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted March 14, 2009 Report Share Posted March 14, 2009 Drain it again into an aluminum pan and you can reuse it. It takes 1 full quart and 1/2quart Quote Link to comment Share on other sites More sharing options...
skinindustries Posted March 14, 2009 Report Share Posted March 14, 2009 you put a quart and a half in there??? damn that seams like ALOT of oil.. my dirtbike only takes 800cc. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted March 14, 2009 Report Share Posted March 14, 2009 did you have the hose just hanging? Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted March 14, 2009 Report Share Posted March 14, 2009 isnt it 1.7 total if its totally empty? and then 1.5 for periodic oil chnages. then alot of people say they put in closer to 2 quarts to prevent something from welding itself to something else.. i dont know, but im pretty sure ive read that before Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted March 14, 2009 Report Share Posted March 14, 2009 you put a quart and a half in there??? damn that seams like ALOT of oil.. my dirtbike only takes 800cc. thats because its a dirtbike Quote Link to comment Share on other sites More sharing options...
TJScott Posted March 14, 2009 Author Report Share Posted March 14, 2009 yes, i just realized the hose was just hanging there. good call. Quote Link to comment Share on other sites More sharing options...
Tapatalk Posted March 14, 2009 Report Share Posted March 14, 2009 i put 2 in Quote Link to comment Share on other sites More sharing options...
spurdy Posted March 14, 2009 Report Share Posted March 14, 2009 So first time filing up the banshee with tranny fluid since im just now getting that far in the build, i saw 1500cm3, and mistaked it for 1500cc's. i poured in a little over 1200cc's of oil since thats all i had. i turned around and there was fluid everywhere, it was coming out of the hose that is supposed to route above the access panel by the water pump, i dont have an access panel btw. so i saw it was overfull and let it run out. i come back 20 minutes later, and its still dripping out. i check the dipstick and its a little under half. so why did it continue to drain? is it even supposed to be leaking? 1500 cm3 is centimeters cubed. 1200 cc i cubic centimeters. You were 300 cc or cm3 short. Thus the draining through your hanging hose. Got the equation now? Should take 1.5 liters which is equal to almost 1.6 quarts. SP Quote Link to comment Share on other sites More sharing options...
Rodneya Posted March 14, 2009 Report Share Posted March 14, 2009 1 cc is the same as 1 ml is the same as 1cm3. Your banshee takes 1.5litre (1500ml) when you change the oil and 1.7litre (1700ml) if you have had the clutch cover off. If you only put in 1200cc or 3/4 of the oil required it should not be leaking. Overfilling slightly wont do anything to your motor Quote Link to comment Share on other sites More sharing options...
TJScott Posted March 14, 2009 Author Report Share Posted March 14, 2009 yes, i was mistaken. i was overcomplicating things as usual and got an incorrect measurement. hopefully routing that hose correctly will stop the leakage. btw, does anybody know if i NEED to to have an access panel? its already saved me once not having one. Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted March 14, 2009 Report Share Posted March 14, 2009 yes, i was mistaken. i was overcomplicating things as usual and got an incorrect measurement. hopefully routing that hose correctly will stop the leakage. btw, does anybody know if i NEED to to have an access panel? its already saved me once not having one. what access panel? Quote Link to comment Share on other sites More sharing options...
TJScott Posted March 14, 2009 Author Report Share Posted March 14, 2009 it goes over the water pump cover. i see no need for it, except maybe for assurance that you dont break the water pump cover, idk. Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted March 14, 2009 Report Share Posted March 14, 2009 it goes over the water pump cover. i see no need for it, except maybe for assurance that you dont break the water pump cover, idk. because it looks crappy without it. and as the little breather thing the tube comes out of i pluged that thing up with jb weld its useless. Quote Link to comment Share on other sites More sharing options...
TJScott Posted March 14, 2009 Author Report Share Posted March 14, 2009 um, its a breather tube, its necessary. not trying to be smart or anything, just sayin... Quote Link to comment Share on other sites More sharing options...
