30mm oko question
kaptainkx
Alright, I got these carbs today and have them installed, seem to be an okay carb, kinda cheap quality imo. My question is, what have you guys done to get clearance for the clutch, the nut on the bottom of the bowl is rubbing the top of the clutch, I slightly bent the clutch linkage down, this helped, but not the cure. I even put the crap reed spacers that came with the quad back on to get the clearance, but still not enough. thanks in advance guys.
kap
Grind a bit off of the nut. Leave some though, so you can remove it for easy main jet access.
