electrical or fuel?
kingkong
my 421 cheetah runs good while its cold after it warms up it starts banging out. i have jetted it up and jetted down and it still has a bad bang everytime it warms up. could it be my coil,cdi, or stator i dont know
a bang is missing..runs fine till it warm up and will start popping then at 1/2 to full throttle..you can hear it sometimes only hitting on 1 side..1 side will be running fine and the other side will be popping..compression is fine and carbs have been cleaned several times.. plugs have been changed
Check your spark plug boots, could have blown resistor.
well i finally found why the cheetah been missing..after i have cleaned the carbs 10 times and changed plugs and run compression check i had just about gave up..i have a stock banshee frame in the back yard so i decided to try the coil off of it since i have done everything else..mounted this 5 r 6 year old coil on here and it runs like a 421 cheetah suppose to now..this thing will pull the wheels in 4th gear now..it has always had a lil miss every since i brought the bike but it slowly start getting worse..never thought it could be the coil cause it would hit sometimes on 1 cylinder like the carbs wer acting up then it would start back hitting on both cylinders..well while i was trying to find the problem i made a few oter changes..bumpd timing up from 4 to 7 and went from 93 octane to 104..it has a wheelie bar on it and will touch the wheelie bar in every gear now...also big shout out to jeff at f.a.s.t. i was gettin ready to buy an override cause this thing will not hardly shift...jeff told me the modded shift shaft will improve my shifting..this thing now shifts like it got an overide...so all you guys thinking bout buying an override i suggest you try the jeff's modded shift shaft
Impossible.
Glad you got the coil figured out.
I've ridden modded bikes with shift mods, stars, Blaster rollers, Yakkey Shift drums, etc. Yes, they shift better than stock. Hell, anything does that's why they make so many things to help them shift better.
You've either never ridden a bike on an override...or don't have the power needed for one.
Anything shifts better than stock.
NOTHING shifts like an override. It's physically impossible.
If you're happy how it runs and shifts, that's the most important part.
But saying it shifts like it has an override is false...there is nothing "like" an override, you can either bang shifts all day under full throttle or you can't.
If you're telling me you can do EXACTLY that on your bike now, it'll break soon...promise.
Impossible.
ok i might have over done it...it doesnt shift like an override...you do have to get off the gas to shift but it will shift...at first it wouldnt shift no matter what...guess i got a lil over excited since i been chasing gremlins with this thing every since i had it...the modded shift shaft do work but you will have to get off the gas...and yes it does hav the power
