help me out with tuning
So I started trying to tune one of my shees today, since it was warm out, this is my first time doing it. The bike is stock internally, and has t5s, pods, +4 timing, 310 jets, and the long dynojet needles on the 4th clip. I got the idle set good, and the carbs are synced with my sync tool. Air screws are 1.5 out. When driving, the bike is ok right off idle, but bogs if you give it a lot of gas, then takes off. If you rev it up high, it also seems to be backfiring slightly. This seems like it is too rich correct? Now do I need to adjust the needles or the air screws?
i dont really have anywhere i could run it all out, i keep the bikes in westchester. if i cant get it running well before it gets warmer, i will just trailer them out to the island, where do you run them? i thought LI was locked down as far as quads go.
it seems better with the 300 and on the 3rd clip, im still having a problem with it bogging at low throttle.
i have had literally the exact same problem as you if this is your problem:
you go slow lets say on first gear.. ( very slow), then randomly quickly gas it full and then quickly let go.. and then it makes a deep bog noise.
if thats your case, and you are running 25 pilots and 1.5 turns out on airscrew.. thats your problem.
i also have same mods as you.. and when i turned my airscrew in.. it became SO much better.. eventually i got it to only 1/2 a turn out.
try turning it in 3/4 in or atleast 1/2 turn more in. see if it makes it better, if so, go more deep in.
put back your old main and clip if it was running better at top.
your low end thing is your AIR SCREW guarantee.. as much as i dont know shit im sure about this one.. i had the same problem.. tighten that air screw alot :)
Edited by blaster2006
for now, put your shorter needle back in, and drop it all the way lean. it won't have as much power as 27.5+ longer needle, on the low end, but it should run better. or did you already get the 27.5's?
Edited by AKheathen
