jbooker82 Posted March 6, 2009 Report Share Posted March 6, 2009 Deffinatly do the stroker. The longer stroke helps strenghtin the mid range torque. The people that port your cylinders should be able to port them for the four mill. That way you dont run the spacer, just a pair of cut stroker domes. Quote Link to comment Share on other sites More sharing options...
Johnny_3_Tears Posted March 6, 2009 Author Report Share Posted March 6, 2009 Deffinatly do the stroker. The longer stroke helps strenghtin the mid range torque. The people that port your cylinders should be able to port them for the four mill. That way you dont run the spacer, just a pair of cut stroker domes. Right on, thanks for the advice. Quote Link to comment Share on other sites More sharing options...
