Oil Injector
i need your experience on this subject.
I need to block off the injector on a 2004 Bombadier DS 90. I believe it would be the same as the Blaster which always has the oil injector going bad. Any help would be great
WOW! :blink: :blink:
I've owned several Banshees and have no clue how to tell you to do this. I guess my best answer would be to look at it, contemplate, and come up with a plan of action and implement it. Past that I can't help you. I've never owned a Banshee that was oil injected. Not being a smart ass (well, maybe a little) but damn! I little investigation and I bet you can figure it out!
Maybe a little less general question would generate a better suited response.
SP
Edited by spurdy
^^LMFAO Dude just open her up pull the little plastic gear that drives the auto lube pump, buy the block off plate and plug the lines. (That does not mean you dont have to mix fuel though. :biggrin: Wait....You knew that though right???
