Gain anything from porting Cubs
b-nasty
I know Nate Mccoy at Mccoy's perf and Dan Hull at A/S can get a few more hp out of them. I always heard 3 to 8 hp. For $300 if you are really into draggin it might be worth it but they are pretty stout left alone too.
Calvin has gotten the cub cylinders real close. Some of the top builders don't do portwork on the cub cylinders anymore.
That's why you can buy them ready to bolt on.
I know there is a company that is changing $500 to do porting on cub cylinders.
Ask around for pricing on portwork. $300 plus is for DM and bigger cylinders.
  • 2 weeks later...
That is simply not true. There is a lot to be gained from a cub cylinder by porting it. Not only is there something to be gained from "just" port work, but it will be set up to work in unison with your pipes, combustion, and intake.
No builder is going to want put their name on a cylinder without porting it, and I have never heard of a "top" builder saying a cub couldn't use a little work.
Obviously, compared to a stock cylinder with OEM porting vs a very good port job, you will NEVER see that kind of increase.
But you can get more ponies out of them...without a doubt. Koolguy made a very good point.
It's not just grinding on a cylinder, it's the WHOLE package for the motor, and then the setup to get that power to the ground efficiently.
