screatching sound from rear end?
bike is making crazy sounds when im driving she will buck and it sounds like there is alot of friction and rubbing comming from the rear end?or it could be close to the front sprocket not sure where sound is comming from, i havent checked gear oil in a while, also maybe rear end needs lube bad? whats going on!!!!sound gets worse when i turn bike...
x2 on the carrier bearings! mine did the exact same thing just changed em. Do not ride with em like that, axle will whollow out ur carrier and u will have to buy a new one cuz the bearings wont fit.
I would change them now before it is too late. I just changed mine in the nick of time. If you need some I would check out ebay seller Racegirlsrock thats where I got mine from.
Likely bearings are bad. They are standard bearings also. Any bearing house will have them, probably cheaper then you can get them shipped from anywhere. You just have to measure the ID, OD and width. Measurements are in mm if your wondering.
SP
