mignumspeed Posted February 25, 2009 Report Share Posted February 25, 2009 i've been having trouble with my front brakes,i put new pads on and bled the lines by taking a tube from the bleeder screw to the resevior and pumping the brake lever until the fluid runs clear with no air bubbles,and i also rebuilt the master cylinder, i can't figure it out?it takes like four pulls to get brakes! Quote Link to comment Share on other sites More sharing options...
spurdy Posted February 25, 2009 Report Share Posted February 25, 2009 i've been having trouble with my front brakes,i put new pads on and bled the lines by taking a tube from the bleeder screw to the resevior and pumping the brake lever until the fluid runs clear with no air bubbles,and i also rebuilt the master cylinder, i can't figure it out?it takes like four pulls to get brakes! I would bleed them again and see if you have more air bubbles. The system may be sucking in air. If they are soft I would think it is air in the line again. Air compresses different then fluid. SP Quote Link to comment Share on other sites More sharing options...
uwenr Posted February 25, 2009 Report Share Posted February 25, 2009 i've been having trouble with my front brakes,i put new pads on and bled the lines by taking a tube from the bleeder screw to the resevior and pumping the brake lever until the fluid runs clear with no air bubbles,and i also rebuilt the master cylinder, i can't figure it out?it takes like four pulls to get brakes! Have air in the system. Make sure your pumping then cracking the bleeder and closing it as soon as the fluid stops. If your leaving the bleeder open it will suck air past the threads. Quote Link to comment Share on other sites More sharing options...
someone82 Posted February 25, 2009 Report Share Posted February 25, 2009 i've been having trouble with my front brakes,i put new pads on and bled the lines by taking a tube from the bleeder screw to the resevior and pumping the brake lever until the fluid runs clear with no air bubbles,and i also rebuilt the master cylinder, i can't figure it out?it takes like four pulls to get brakes! You mentioned you rebuilt the master cylinder. Did you hone out the cylinder before putting the new plunger seal in? If not the seal will never properly seat and you have issues like your haveing. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 25, 2009 Report Share Posted February 25, 2009 Trust me when I say this..........Gravity bleed them. Just take off the resevoir cap, take the bleeder valves completely out, and let it bleed on it's own. Keep tapping on the calipers with a wrench, to help get the air bubbles out of the calipers. Make sure you keep filling the resevoir. Let it bleed on it's own for about 30 minutes. It's a slow process, but works great. Just so you know, the fluid isn't going to come out of the bleeders fast, it's going to be slow. Quote Link to comment Share on other sites More sharing options...
someone82 Posted February 25, 2009 Report Share Posted February 25, 2009 (edited) x2 on gravity bleeding, it's almost always a surefire way to make sure your brake system is air free. Edited February 25, 2009 by someone82 Quote Link to comment Share on other sites More sharing options...
redwings Posted February 25, 2009 Report Share Posted February 25, 2009 My fronts are soft to..... I cant lock them up on asphalt....so i take reservoir cap off, bleeders off and let them drain slowly down the calipers while keeping a eye on the fluid level. After 30 min...i put the bleeders back on and thats it.... this must make a big mess.....is this right? I hate my front brakes....can you guys lock your brakes up on asphalt? Mine have always been shit? Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 25, 2009 Report Share Posted February 25, 2009 My fronts are soft to..... I cant lock them up on asphalt....so i take reservoir cap off, bleeders off and let them drain slowly down the calipers while keeping a eye on the fluid level. After 30 min...i put the bleeders back on and thats it.... this must make a big mess.....is this right? I hate my front brakes....can you guys lock your brakes up on asphalt? Mine have always been shit? Yup, that's it. I usually take the wheels off, and stick a catch pan under them. Or, you could keep the bleeders on, stick a clear hose on the nipple, and point it into the catch pan. It's just a little faster without the bleeders on, that's all. Quote Link to comment Share on other sites More sharing options...
mignumspeed Posted February 26, 2009 Author Report Share Posted February 26, 2009 You mentioned you rebuilt the master cylinder. Did you hone out the cylinder before putting the new plunger seal in? If not the seal will never properly seat and you have issues like your haveing. no i didn't , i'm going to try gravity bleeding them if that doesn't work i'll hone the cylinder,is there a special tool to hone with or what do i use? Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 26, 2009 Report Share Posted February 26, 2009 no i didn't , i'm going to try gravity bleeding them if that doesn't work i'll hone the cylinder,is there a special tool to hone with or what do i use? Yea, they're pretty cheap too. They're just regular 3 stone hones, but really small. Quote Link to comment Share on other sites More sharing options...
mignumspeed Posted February 26, 2009 Author Report Share Posted February 26, 2009 Yea, they're pretty cheap too. They're just regular 3 stone hones, but really small. i dont know if this means anything or not but i just looked in the manual and it said in bold black letters do not hone the cylinder!but this may be so they can sell more of them,has anybody actually honed one there self?if so i'll stop at napa and pick up a hone. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 26, 2009 Report Share Posted February 26, 2009 You're putting WAY too much thought into this. Just do it, and be happy with the results. Quote Link to comment Share on other sites More sharing options...
someone82 Posted February 26, 2009 Report Share Posted February 26, 2009 (edited) i dont know if this means anything or not but i just looked in the manual and it said in bold black letters do not hone the cylinder!but this may be so they can sell more of them,has anybody actually honed one there self?if so i'll stop at napa and pick up a hone. I've rebuilt a bunch of master and wheel cylinders before and it's very easy, just make sure you use a good lube and you don't catch the stones on the edge of cylinder. You only need to make a few passes as well, if you make to many you'll lose too much material and the plunger seal won't seal properly. Edited February 26, 2009 by someone82 Quote Link to comment Share on other sites More sharing options...
mignumspeed Posted February 27, 2009 Author Report Share Posted February 27, 2009 I've rebuilt a bunch of master and wheel cylinders before and it's very easy, just make sure you use a good lube and you don't catch the stones on the edge of cylinder. You only need to make a few passes as well, if you make to many you'll lose too much material and the plunger seal won't seal properly. thanks,i'm going to napa tomorrow and get a hone i gravity bled the brakes just like you all said it worked good but the brakes are still soft so i'll hone the cylinder and go from there,its got to be the master cylinder. Quote Link to comment Share on other sites More sharing options...
