tidos76 Posted February 23, 2009 Report Share Posted February 23, 2009 We went to the river today. all in all i had a good time. I found out i need bigger paddles but thats not the big problem. I have never had a problem shifting when i drag race. I rarely missed a gear. Today was a different story. I'd launch in 2nd. full throttle clutch shift to 3rd, full throttle shift clutch to 3rd,ummmm let off roll out of the way sayin wtf!!! so on the return trip to the starting like i go about 1/2 throttle up to 5th. NO problems at all. so next trip down launch in 2nd,full throttle shift clutch to 3rd, NO throttle clutch, shift, STILL IN 3RD!! The motor will shift fine as long as I dont speed shift. i can be on hit hard. just take a lil time to shift, and it works fine. Any ideas? oh and its a stock trany. no shift star, no override(i wish), r6 clutch, hensen<sp> basket. Quote Link to comment Share on other sites More sharing options...
225GUY Posted February 23, 2009 Report Share Posted February 23, 2009 Check out the rod going into the case over on the drivers side. Quote Link to comment Share on other sites More sharing options...
phrog70 Posted February 23, 2009 Report Share Posted February 23, 2009 few things to check. first check the adjustment on the shift lever inside the case next to the star{ in repair manuel} next check the shift rod wear its grabing the star. had one barly grabing it when shifting to next gear but down shift was fine. had to put in vise and bend it a little bit to put it back in the center of the star. hope it helps, it alot easier to show it then write it out. Quote Link to comment Share on other sites More sharing options...
