lokisbuddy Posted February 23, 2009 Author Report Share Posted February 23, 2009 I wouldn't know what to do man...I would rather not mess with it, how do I adjust the tranny? My bike is stock other than the pods and pipes. Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted February 23, 2009 Report Share Posted February 23, 2009 Where your shift shaft is there will be a lock washer and a srtraight screwdriver slot. You will need to remove the clutch basket to see the shift star. Bend back the lock washer, then turn it witch ever way it needs to go. Like I said before make sure your in neutral. I will try to find a pic to help you out. Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted February 23, 2009 Report Share Posted February 23, 2009 This link should help you out. In the first pic you can see how his is way out of wack. You want those "hooks" to be equal distance to the studs on the star. Then in the last pic you can clearly see the lock washer and adjustment slot. He has the arm removed in the last pic, leave yours on. http://www.bansheehq.com/forums/index.php?...haft+adjustment Quote Link to comment Share on other sites More sharing options...
