lokisbuddy Posted February 22, 2009 Report Share Posted February 22, 2009 Can I get a tranny that has the neutral down and have that be the only mod done to it? I don't want no overide or anything I just get sick of missing second and hitting neutral. Quote Link to comment Share on other sites More sharing options...
FadedDreams Posted February 22, 2009 Report Share Posted February 22, 2009 Have you tried a modded shift star with neutral back cut?It wouldn't hurt to try that if you don't already have it done.At least its a pretty cheap mod to have done. Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted February 22, 2009 Report Share Posted February 22, 2009 yep, a modded shift star should help you.. i also grind down the spring on the detent arm to make it a wee bit weaker.. my trail bike shifts great.. but my cub would never shift under full throttle, so it got a dunable overide.. try getting or cutting the star, it does help. Quote Link to comment Share on other sites More sharing options...
coorslight125 Posted February 23, 2009 Report Share Posted February 23, 2009 yep, a modded shift star should help you.. i also grind down the spring on the detent arm to make it a wee bit weaker.. my trail bike shifts great.. but my cub would never shift under full throttle, so it got a dunable overide.. try getting or cutting the star, it does help. i miss second all the time, what is the mooded shift star is there a forum on it Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted February 23, 2009 Report Share Posted February 23, 2009 i miss second all the time, what is the mooded shift star is there a forum on it yep.. use the search button.. its an easy mod.. hell, i cut my own shift stars.. its easy to do.. just have to pull the clutch basket off.. no biggie Quote Link to comment Share on other sites More sharing options...
lokisbuddy Posted February 23, 2009 Author Report Share Posted February 23, 2009 Anyone want to do my shift star for me? What would it cost? Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted February 23, 2009 Report Share Posted February 23, 2009 if you wanna mail it to me i'll cut it for free.. just throw a couple bucks in there to cover return shippin.. take me 5 minutes to do. Quote Link to comment Share on other sites More sharing options...
grizzly700 Posted February 23, 2009 Report Share Posted February 23, 2009 wen i was little and first learning how to ride. i used to miss 2nd all the time on my KX85. then my dad would say stop pussy shifting it. shift it like a man. it hurt my feelings at first but i hardly ever miss gears ne more. i was like 8 lol :yes: Quote Link to comment Share on other sites More sharing options...
lokisbuddy Posted February 23, 2009 Author Report Share Posted February 23, 2009 ^^ Yeah but on the shee its not a matter of pussy shifting because I can hammer it upward from first and sometimes when I pop the clutch it just screams and dont go anywhere So I look like an ass till I correct the problem. :biggrin: I will take the shift star out soon and ship it to you. will it have any negative effects? Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted February 23, 2009 Report Share Posted February 23, 2009 no negative effects at all.. i cut the star in my trail bike, did the one in the ole ladys banshee, and my buddys shee.. they all shift a lot better.. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 23, 2009 Report Share Posted February 23, 2009 Why don't you just grind it yourself? Like sheerider said, it takes 5 minutes. Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted February 23, 2009 Report Share Posted February 23, 2009 ^^ Yeah but on the shee its not a matter of pussy shifting because I can hammer it upward from first and sometimes when I pop the clutch it just screams and dont go anywhere So I look like an ass till I correct the problem. :biggrin: I will take the shift star out soon and ship it to you. will it have any negative effects? sounds like you may need to adjust it a little. If you are rolling and you shift it up all the way, it should click in. If your adjustment is off, it may not be letting you get full range out of it. Shift star is easy. It helps to go by a photo the first time though. Quote Link to comment Share on other sites More sharing options...
okbeast Posted February 23, 2009 Report Share Posted February 23, 2009 Also make sure your shift shaft is adjusted properly. Any stock bike should be able to shift fine. Quote Link to comment Share on other sites More sharing options...
boneyardbanshee. Posted February 23, 2009 Report Share Posted February 23, 2009 yep thats what I was refering to. With it in neutral, the "hooks" should be evenly spaced to the pins on the star. Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 23, 2009 Report Share Posted February 23, 2009 I just did this earlier tonight to my shift star. If you missed it, here's the thread with a pretty big picture. You can't screw it up. It's almost impossable. This is the first one that I've ever done. Hope that helps. http://www.bansheehq.com/forums/index.php?...mp;#entry951943 Quote Link to comment Share on other sites More sharing options...
