swhitey917 Posted February 21, 2009 Report Share Posted February 21, 2009 Hey guys, i am having a little trouble. does anyone now away to get tie rods out of the spindles. i have been beating on these things for the last hour and they are not moving a bit. please help, these are the only thing slowing down my winter rebuild. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted February 21, 2009 Report Share Posted February 21, 2009 the tie rods unscrew dont they? Quote Link to comment Share on other sites More sharing options...
swhitey917 Posted February 21, 2009 Author Report Share Posted February 21, 2009 the tie rods unscrew dont they? i unscrewed the nut off and everything i just can't pull the rod out of the spindle. Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 21, 2009 Report Share Posted February 21, 2009 i unscrewed the nut off and everything i just can't pull the rod out of the spindle. grab a hammer and hit the spindal and put some down force on the tie rod.it will pop right out.. Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted February 21, 2009 Report Share Posted February 21, 2009 the tie rods unscrew dont they? im sure he means balljoint dilbert. i used a flywheel pulleer rig in between both ends and turn it open to press one out then find a way to make a spacer to press out the other one. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted February 21, 2009 Report Share Posted February 21, 2009 im sure he means balljoint dilbert. i used a flywheel pulleer rig in between both ends and turn it open to press one out then find a way to make a spacer to press out the other one. hahaha! i was wondering why he was beating on the tie rod! my bad :shoothead: Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted February 22, 2009 Report Share Posted February 22, 2009 grab a hammer and hit the spindal and put some down force on the tie rod.it will pop right out.. Yup. Should be able to smack it one good time, and it will come right out. Quote Link to comment Share on other sites More sharing options...
swhitey917 Posted February 24, 2009 Author Report Share Posted February 24, 2009 they are still not coming out.....very frustrating. Quote Link to comment Share on other sites More sharing options...
Black&Red87 Posted February 24, 2009 Report Share Posted February 24, 2009 (edited) they are still not coming out.....very frustrating. put it in a vice and get a 10 dollar ball joint seperator(fork style). that should do the trick if you tried the other suggestions. If all else fails get a bigger hammer! Edited February 24, 2009 by Black&Red87 Quote Link to comment Share on other sites More sharing options...
swhitey917 Posted February 24, 2009 Author Report Share Posted February 24, 2009 put it in a vice and get a 10 dollar ball joint seperator(fork style). that should do the trick if you tried the other suggestions. If all else fails get a bigger hammer! I am to the point to where i dont think they make a bigger hammer :biggrin: Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 24, 2009 Report Share Posted February 24, 2009 Didnt read everything but did u try some heat on the spindle,put some heat on it,thread nut on backwards,air chisel with blunt end and hiter up(dont try this at home kids) Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted February 24, 2009 Report Share Posted February 24, 2009 put it in a vice and get a 10 dollar ball joint seperator(fork style). that should do the trick if you tried the other suggestions. If all else fails get a bigger hammer! if you have them PC'd and dont want to messup the coating this is the way to do it. If not you can get a 3 point puller and get it off. it's a little difficult to get it to bite and stay on but its possible. i had to do it with mine too. Quote Link to comment Share on other sites More sharing options...
bonbon Posted February 24, 2009 Report Share Posted February 24, 2009 Didnt read everything but did u try some heat on the spindle,put some heat on it,thread nut on backwards,air chisel with blunt end and hiter up(dont try this at home kids) You beat me to it. Put the nut on so you don't jack up threads, heat up the end, then give it a good whack. Mine popped out after 2 times heating and hitting. I was having absolutely no luck without heat. I got it done without a vise too. Quote Link to comment Share on other sites More sharing options...
BlasterKX Posted February 24, 2009 Report Share Posted February 24, 2009 i would also have to say heat the spindle up so it expands and hit the tie rod end a couple good times with the nut threaded on there. good luck!!! Quote Link to comment Share on other sites More sharing options...
swhitey917 Posted February 25, 2009 Author Report Share Posted February 25, 2009 thanks everyone. i got them off today finally. Quote Link to comment Share on other sites More sharing options...
