I got my asv clutch lever the other day and the adjuster nut on the inside hits the stock killswitch housing so you cant pull the clutch in all the way. Anyone else have that problem?
Mine did the same thing. Even though the lever doesn't pull all the way to the grip it will still engage the clutch. If your worried about it, you could the put the killswitch on the other side of the perch.
  • Replies 173
  • Created
  • Last Reply
Top Posters In This Topic
mine comes close, to it, but i relized when im riding i dont even pull my clutch in half that much so...im not worried. if it really bothered me, id move the switch to under my frame or seat
Oh ya I forgot about that. I cut the adjuster bolt down to a minimum and put a regular nut on it. Also, the bulk part of the lever hits the kill switch, so you have to rotate the kill switch to get it to clear.
I was thinking put a tether in place of the stock kill switch, then wiring the headlights to a switch under the seat by where i relocated the key.
ALL you do it loosen the kill swith and rotate it forward's about a 1/8-1/4 turn then tighten again. Problem Fixed
Pretty straight forward, if you look at the housing on the kill you will see how the housing gets smaller and more room as you rotate it Forwards.
All you had to do was look at it and see why it was hitting it and how to fix the so called "problem" and would have figured it out. :ninja:
Edited by savage420
Tried that when i first put it on. But having your kill switch on an angle just looks retarted.
mine should be here this week...
zach did you get the levers yet?
let me know if you have any questions on the install, but im sure you wont.
peter
peter
dogs are flipping out so they might be here...
im sure ill get it if anything ill ask... thanks peter..
Zach if you can post some pics . I want too see what the refrubs look like. no big marks on then ect..?
So turning is a 1/4" more look's retarded to what? OK :blink:
Than have it the way you want it then..... :shoothead:
